Compatibity with previous charger
  1. AlessCammarata
    Cupcake May 15, 2019
  2. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer May 15, 2019
    KeepTransisting , May 15, 2019 :
    Yes. I have a 7 Pro and plugging in my old dash charger shows "Charging Rapidly"
    It just won't charge as fast as the warp charger
    rehjer80 and AlessCammarata like this.
  3. AlessCammarata
    AlessCammarata , May 15, 2019 :
    Okay,
    the battery will not be damaged? Otherwise, that's good news!
    Thanks
  4. KeepTransisting
    Well, considering that warp charging is hella more powerful than dash charging, it would be impressive if it hurt the battery :p
    AlessCammarata likes this.
  5. ShehryarHussain786
    Ice Cream Sandwich May 16, 2019
    ShehryarHussain786 , May 16, 2019 :
    Wrap charge is back ward compatible so if you use it with any older device such as 3, 3t,5, 5t, 6 or 6t. They will charge at 20watts 5v 4amp. That's only as long as the battery is under 70%. Above that the battery charge slow.
    Whereas if you use that on 6t mclaren and 7 pro they will charge at 5v 6amp 30watts maximum when the battery is under 70%.
    On the otherway of you is the dash charge on any of these devices they will charge at 20watts max. With the same rule for under 70% battery apply.
  6. ShehryarHussain786
  7. AlessCammarata
    Cupcake May 16, 2019
