Compatible Best Type C cable For Oneplus 2 ?
  1. tanmaysalunke
    Gingerbread Dec 2, 2016
    tanmaysalunke , Dec 2, 2016 :
    Please Help me out to select One Best Original Type C cable In INDIA as Amazon.in Doesnt Have the Original One .
    Please Help me out
    I m facing Charging Issue such as
    My Oneplus 2 ( Running on CM 13 ) takes 5-6 Hours To charge sometimes (Once In a while)
    So Is Something Wrong With CM 13 or Type C Cable .
    Please Do Help Guys
  2. Akshat2793
    Ice Cream Sandwich Dec 2, 2016
    filipe.aparicio likes this.
  3. filipe.aparicio
    filipe.aparicio , Dec 2, 2016 :
    Is your cable damaged? (has bents, was chewed by a pet, etc.)
    Did you notice this only after CM13 or before?
  4. tanmaysalunke
    The issues Came from last 2-3 Updates from CM 13
    Surely Its the issue In either Cable or Charger
    Because I Just Now charged My Oneplus 2 with Samsung Galaxy S7 Edge' Charger
    7% - 43 % in Roughly 30 minutes .
    And My Warranty is Over So need to buy the OG from Service Center itself
  5. jatinkalra07
    jatinkalra07 , Dec 2, 2016 :
    access type c cable
  6. piyushsoni24
    Gingerbread Dec 3, 2016
    piyushsoni24 , Dec 3, 2016 :
    Mivi type c cable from amazon.in
  7. sahil_sharma
  8. rishi pahwa1
    Cupcake Dec 3, 2016
    rishi pahwa1 , Dec 3, 2016 :
    ee
    Even my charging cable that came out of the box gave up on me. One way to check if the wire or the charger is working fine on Oxygen OS (not sure if it works on Cyanogen) is
    Step 1. go to dialer and dial *#808# (and you will enter into a world never seen before:) )
    Step 2. scroll down to "Charger" option (see screenshot)
    Step 3. after selecting give it a few minutes to calibrate and it will show the message "Pass" or "Fail".
    I would suggest you go to a local dealer and check the cable in front of the dealer following the above process and buy one because i could not find a good cable on amazon too.
    To check whether anything is wrong with your charger:
    you need an out of the box wire (ask a friend) and follow the above steps with the charger you are using (vice versa to check the cable)
    Gragasaki and tanmaysalunke like this.
  9. aaronblaze
    Cupcake Dec 3, 2016
    aaronblaze , Dec 3, 2016 :
    Try searching Regor Usb-C at amazon..I have tried a couple of cables ..
    Regor one is the best..Got around 1600-1700mA per second charging speed..
    tanmaysalunke likes this.
  10. G_Nishant_Choudhary_tSxP
    Cupcake Dec 3, 2016
  11. tanay09
    Donut Dec 3, 2016
    tanay09 , Dec 3, 2016 :
    but type c adapter and use them on micro USB cables cheap and best else there are many option at different price range in amazon
  12. tanmaysalunke
    tanmaysalunke , Dec 3, 2016 :
    thank you soo much
  13. tanmaysalunke
    No My Friend .
    Please Have a look on the reviews
  14. tanmaysalunke
    even the Service Care Said me the same
    Dilip_raju and sahil_sharma like this.
  15. buddydave
    Honeycomb Dec 4, 2016
    buddydave , Dec 4, 2016 :
    I've had two anker cables since since I bought bought the phone in November last year. Both of them look brand new even though I've used them everyday and have been thrown around everywhere. So anker is definitely worth a buy!
  16. Praty_28
    KitKat Dec 4, 2016
    Praty_28 , Dec 4, 2016 :
    I always get below 1000 ma on my original oneplus cable its approx one year old... Should i buy a new one? But phone is charging from 20 to 100 in approx 2 hrs
  17. iAnkur
    Gingerbread Dec 4, 2016
    iAnkur , Dec 4, 2016 :
    no need to find any original one plus cable on Amazon bro go to market and purchase usb type -c its cost approx. 150 rs the cable seems exactly look like as one plus cable and it will charge your phone normally
  18. user 7
    Ice Cream Sandwich Dec 4, 2016
  19. tanmaysalunke
    tanmaysalunke , Dec 4, 2016 :
    Dont . Everything is Perfect
  20. tanmaysalunke
    From where did you bought it ?
