Compatible Best Type C cable For Oneplus 2 ?
  1. user 7
    Ice Cream Sandwich Dec 6, 2016
    user 7 , Dec 6, 2016 :
    I use a redmi note 3 cable and xiaomi adapter to charge op2.. Works ok
  2. britishmisk
    Cupcake Dec 6, 2016
  3. devensingh
    Cupcake Dec 6, 2016
    devensingh , Dec 6, 2016 :
    I had faced the same issue. It used to take 6-7 hours to fully charge the battery. I bought "Portronics Konnect 3 in 1" USB. It has a Type C, Micro Usb & Lightning cable. Search for it on Amazon.in... Now my phone gets charged in 2 hours.
  4. SuperTacoMonkeyExplosion
    Ice Cream Sandwich Dec 7, 2016
    SuperTacoMonkeyExplosion , Dec 7, 2016 :
    Cables are NOT made the same. Check out this reviewer..... Buy what he recommends, don't burn your phone or house down
    https://plus.google.com/ BensonLeung/posts/LH4PPgVrKVN
    tanmaysalunke likes this.
  5. iAnkur
    Gingerbread Dec 7, 2016
    iAnkur , Dec 7, 2016 :
    bro go to market in your city and take any usb type c cable I am also facing this issue but after changing the cable it will be fully solved no need to purchase a origional cable because I think after the volte update this problem will be particularly solved and we also know that only some days are left in hitting the oxygen os (volte update)
  6. dhruvgupta21
    Gingerbread Dec 27, 2016
    dhruvgupta21 , Dec 27, 2016 :
    Hey rishi thanks for this. I ran this on my OP2 as i've been experiencing really slow charging. For me the test never ended and though other values were comparable with voltage in red, but the curent was really low. Can you help me?
  7. Adityalaad
    Froyo Dec 27, 2016
  8. tanmaysalunke
    tanmaysalunke , Dec 27, 2016 :
    me too
  9. tusar8
    Jelly Bean Dec 27, 2016
    tusar8 , Dec 27, 2016 :
    Buy the dash cable.
  10. lokesh_171
    Eclair Dec 27, 2016
    lokesh_171 , Dec 27, 2016 :
    Hi
    i tried many of the otg cabel of different brands
    every brand dosent support with oneplus two
    it supports charging but non with data transfer
    suggest some of the otgs if possible link them bellowin the comment section
  11. Harshal jadhav
    Froyo Dec 27, 2016
  12. TILAK92
    TILAK92 , Dec 27, 2016 :
    Buy xiaomi type c adapter and any normal micro usb otg cable. Trust me only this will work nothing else will work, even oneplus type c otg cable will not work. Simply buy xiaomi type c adapter from ebay and thats all.
  13. truenoong
    Cupcake Dec 27, 2016
    truenoong , Dec 27, 2016 :
    Always have been using Anker PowerLine+ series for third-party cable. Fast, durable and I highly recommend it.
  14. Pankaj_Parasar
    Froyo Dec 27, 2016
  15. dmroopesh
    Ice Cream Sandwich Dec 27, 2016
  16. Vatsal Chauhan
    Froyo Dec 27, 2016
  17. rahilmodi97
    Ice Cream Sandwich Dec 28, 2016
    rahilmodi97 , Dec 28, 2016 :
    Buy the Amazon basics type c cable they are genuine and will work for sure and they come with 1 year warranty against manufacturing defects.
  18. tanmaysalunke
    Gingerbread Dec 28, 2016
    tanmaysalunke , Dec 28, 2016 :
    I got a xiaomi OTG Adapter from Manish Market for 100/- .
    Works Just Awesome for Both charging and Data Transfer
    #38
  19. Siddhesh Vijay Kudtarkar
    Honeycomb Dec 28, 2016
    #39
  20. rrathor
    Cupcake Dec 28, 2016
    #40
