Compatible issue with Jio network.
  1. maddy045
    Eclair Oct 17, 2019
    maddy045 , Oct 17, 2019 :
    hi,
    i am using OnePlus 5 since 2 years. I am using both Jio and Vodafone/BSNL sims together. when use data connection of Vodafone/BSNL The Jio network deactivates. i even enable VoLTE for permanently. still problem not solved.
    can somebody guides any trouble shooting tips
  2. Blue-agila
    Ice Cream Sandwich Oct 17, 2019
    Blue-agila , Oct 17, 2019 :
    Are you having a laugh?.
  3. shambo30
    Cupcake Oct 17, 2019
    shambo30 , Oct 17, 2019 :
    Op5 doesnt support dual volte. And Jio only supports Volte. Switchover to Snapdragon 845/855 for dual volte
  4. maddy045
    Eclair Oct 17, 2019
    Reallly, i thought i have duel VoLte[e]1f623[/e][e]1f62d[/e]
  5. Waveform Modifier
    Marshmallow Oct 17, 2019
  6. maddy045
    Eclair Oct 17, 2019
    whats the remedy?
    but the BSNL network not a VOlTE network.then also Jio is not working
  7. Waveform Modifier
    Waveform Modifier , Oct 17, 2019 :
    There is none. Get another phone.
  8. maddy045
    Eclair Oct 17, 2019
    suggest one. if yu dnt mind
  9. Malg220
    Malg220 , Oct 17, 2019 :
    If it is so bad JIO, why do you use it with OnePlus?, Jio does not want to homologate the IMEI to activate VoLTE.
  10. Waveform Modifier
  11. maddy045
    Eclair Oct 17, 2019
    yeah got that, can yu suggest a mid range phone which supports duel volte??
