Conditional Forwarding
  1. DickyMoe
    Cupcake Oct 26, 2021
    DickyMoe , Oct 26, 2021 :
    I can't get the conditional forwarding to work on my OnePlus 7T. When I attempt to enter the MMI codes I get the following error:
    When I attempt to update through the phone dialer settings, I get this error:
    I have tried several SIM cards at this point. Any ideas about what might be causing it?
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 26, 2021
    Dresa91 , Oct 26, 2021 :
    Did you contact the network provider?
    DickyMoe likes this.
  3. DickyMoe
    Many times and am in ongoing conversation with them. Apparently with GSMA (ATT) they can do a manual over-ride, which solves my problem but I would like to have the feature work on my phone. Also did a master reset (the network provider's recommendation) and that didn't solve it either.
    EDIT: the provider is Red Pocket (GSMA)
  4. Dresa91
    Are you using a provider edition phone?
  5. DickyMoe
    No, I'm using a 7T unlocked version.
  6. DickyMoe
    It looks like there are several threads on this forum regarding this issue, and so far it doesn't look like anyone has found a fix.
  7. Dresa91
  8. DickyMoe
    UPDATE: the carrier has fixed it from their end but it still seems like a hardware issue?
  9. Dresa91
    If it is a hardware issue, please contact the support via www.oneplus.com/support and get your device checked
  10. DickyMoe
    Already did that and they told me to post it in Community.
  11. DickyMoe
  12. Dresa91
