46
Confirmed - Extention USB3.0 A-M to A-F Cable Supports OP3 DASH Charging
  1. sbooth
    US Brand Ambassador Jul 6, 2016
    sbooth , Jul 6, 2016 :
    As I mentioned in another thread, in theory, a quality USB3.0 cable with 22AWG wiring should be able to function as an extension to the stock OnePlus Dash charging/data cable for those who need a longer length solution. The main reasoning behind my theory is the USB connector pin-out used on the USB-A side of the factory DASH cable is basically the same as a USB3.0-A connector, but without the high speed data TX/RX lines (see below).
    Well, today I received the cable to test this theory and I am happy to share it DOES work. :eek::cool:
    Items used:
    (1) OnePlus 3 - new/fresh/stock out of the box with OOS 3.1.3 installed from the factory.
    (1) Dash charger - new/fresh out of the factory box.
    (1) Dash chrager/data cable - new/fresh out of the factory box.
    (1) Sabrent 22AWG USB 3.0 Extension Cable - 3 Feet (CB-3030) from Amazon USA.
    Now that I have confirmed the 3 foot cable works, the longer 6 and 10 foot cables should also be viable. Hope this info helps until a low cost complete DASH compatible solution is developed.
  2. luxuskamel
    Marshmallow Jul 6, 2016
    thesplitter and Darkequinoxx like this.
  3. Jebusfreek666
    Gingerbread Jul 6, 2016
    Jebusfreek666 , Jul 6, 2016 :
    Thank you for doing the leg work on this! I will definitely be doing this in my house and in the car to hide the charging cable. Have you tested to see if the charge times are equal with the extender? I would think that they would be very similar, but could see losing just a tiny bit of speed depending on length.
    shiv1g and Joyyy like this.
  4. sbooth
    No noticeable difference that I can see thus far. :)
    Deepak.Si likes this.
  5. rswinney99
    Gingerbread Jul 7, 2016
    rswinney99 , Jul 7, 2016 :
    The way that phone is sitting on over the empty box on the edge of the counter top is making me cringe. I just wanna scoot it back some. :eek:
    shiv1g, PritamX, Custnam and 6 others like this.
  6. Professorchaos1
    Honeycomb Jul 7, 2016
    Professorchaos1 , Jul 7, 2016 :
    Sometimes you gotta live dangerously ;)
    shiv1g, Custnam, techygeek and 2 others like this.
  7. jerrymilton
    Jelly Bean Jul 7, 2016
  8. TrueBrush
    Ice Cream Sandwich Jul 7, 2016
  9. whoamanwtf
    Donut Jul 7, 2016
    whoamanwtf , Jul 7, 2016 :
    Well I guess I will have to order the 6 foot right now and try it out, I live close and have prime so will update within two days.
  10. Deepak.Si
    KitKat Jul 7, 2016
    Deepak.Si , Jul 7, 2016 :
    He just found a way for using dash charge via extension cable.....give people some time maybe they'll come with a complete cable..!!
    bart877ie and techygeek like this.
  11. crysen
  12. DTONE
    Staff Staff Member Jul 7, 2016
    DTONE , Jul 7, 2016 :
    test
  13. grk007
    sbooth likes this.
  14. N7Q
    Cupcake Jul 7, 2016
    N7Q , Jul 7, 2016 :
    I just ordered the 2 metre version (3060) as the 3030 version in OP was not available in Europe.
    I'll let you know if the longer one also works with Dash.
    sbooth likes this.
  15. whoamanwtf
    Donut Jul 10, 2016
    bart877ie, Loveit, r25txe and 2 others like this.
  16. meatandy
    Oreo Jul 12, 2016
    meatandy , Jul 12, 2016 :
    Thanks for your find .
    Sun90 likes this.
  17. N7Q
    Cupcake Jul 13, 2016
    N7Q , Jul 13, 2016 :
    Yes, confirmed.
    I'll check amperages when I get a chance.
  18. Xmanofsteel69
  19. kimop4
    Froyo Jul 13, 2016
    kimop4 , Jul 13, 2016 :
    According to my search, cable marks show "AWM STYLE 2725" which refers to AWG26-28 so I think the Amazon cable is higher quality than Sabrent and should work. Maybe someone can test the Amazon and report back.
  20. Xmanofsteel69
    Xmanofsteel69 , Jul 13, 2016 :
    If I'm not mistaken, isn't the lower the number the better quality/thicker the wire? If it's higher I'd assume it probably won't work :(. Darn
