connect with laptop
  1. deepakgarg0804
    Cupcake Dec 13, 2017
    deepakgarg0804 , Dec 13, 2017 :
    I am not able to connect phone to laptop using cable. What should I do. I have changed cable also. What should I change in phone setting? Or there is hardware problem
  2. ghostbeetle1
    ghostbeetle1 , Dec 13, 2017 :
    when you connect your phone with your laptop, swipe down the notification bar and change it to file transfer files or you can go to developers settings and change it there
    deepakgarg0804 likes this.
  3. deepakgarg0804
    Cupcake Dec 19, 2017
  4. ghostbeetle1
    ghostbeetle1 , Dec 19, 2017 :
    have you tried checking the cable?
  5. RamboH
    Gingerbread Dec 19, 2017
  6. thomas242
    thomas242 , Dec 19, 2017 :
    just remember all cables are not created equally and some really inexpensive cheap cables will not allow file transfers. it has been my experience that the $5 cable off at Amazon is only good to charge the phones
  7. 8755083769
    Eclair Dec 20, 2017
    8755083769 , Dec 20, 2017 :
    open developer option n off the usb debugging.....n if its off thn make it on thn check on lappy....its not nessessory its your phone or cable problum...some time lappy doesn't detect the hardwere....
