3
Connect xbox one controller with android? (need help)
  1. Silverchaoz
    Lollipop Jan 21, 2015
    Silverchaoz , Jan 21, 2015 :
    hey
    just got an otg cable from our lovley forummember @GeertBerkers.
    but now i have a problem
    i can connect my mouse and it works immeidatly
    but i CANT connect my xbox one controller and cant use it....(yes i googled and i only see xbox 360 controllers and xbox 360 and xbox one controller are totally not the same for android)
    does somebody know an app or something else who can help me?
    joantheboss3, lnxpro and GeertBerkers like this.
  2. Silverchaoz
    bestlands and lnxpro like this.
  3. Milad
    lnxpro and Schlumi like this.
  4. miguelri69
    Cupcake Jan 21, 2015
  5. badger906
    Jelly Bean Jan 21, 2015
  6. Silverchaoz
    Me 2. But that thing is almost broken
    lnxpro likes this.
  7. lnxpro
    Silverchaoz likes this.
  8. ganstakillerz
    Ice Cream Sandwich Jan 21, 2015
    leemartin likes this.
  9. Silverchaoz
    yes i konw they work and i tried mine and it worked. but its broken on some buttons so i cant use it...
    lnxpro likes this.
  10. ganstakillerz
  11. lnxpro
    lnxpro , Jan 21, 2015 :
    will try with my cousin's xbox controller on my day off and will let you know on friday :D
  12. Silverchaoz
    thx. do you have a OTG cable and it must be a xbox one :D
    thats the problem, i cant find that app in playstore, yes i know how to search :D
    lnxpro likes this.
  13. lnxpro
    its ok, the OTG its easy to get and my cousin has both xbox, the 360 and the one
  14. gusuraman
    Community Veteran Jan 21, 2015
    gusuraman , Jan 21, 2015 :
    If it is the same as for PlayStation controllers the must be registered in the device they are going to control.
    There should be an app to sync the controller with the phone
  15. teqnix
    teqnix , Jan 21, 2015 :
    @gusuraman to the rescue! *epic theme song playing*
    hemanth97 and gusuraman like this.
  16. Ivanpoocky13
    KitKat Jan 21, 2015
    Ivanpoocky13 , Jan 21, 2015 :
    You gotta connect it with the USB cable and you have to download an app that ask you for root its name is USB/BT Joystick Center 2015.
  17. gusuraman
    teqnix likes this.
  18. Silverchaoz
    can you only see the app if you are root? because i cant find it in playstore. or do you have a link for me? [​IMG]
  19. gusuraman
    I'm rooted but cannot see it
  20. gusuraman
