3
[Submitted] Connection to VPN drops after about a minute.
  1. xer0w
    Froyo Jun 2, 2018
    xer0w , Jun 2, 2018 :
    I have an IPSec VPN setup on my home NAS which I connect to successfully on my OP6, but it disconnects after about a minute.
    This isn’t an issue with my mobile data connection which is stable and fast (I test with okla speedtest)
    I also have a OP5T and this doesn’t have the same issue, it stays connected consistently using exactly the same VPN settings
    The 5T is running OOS v5.1.1 and the 6 v5.1.5
    *Update October 2018. This issue has returned with V9 Pie. *
    GoogleOP6Ike, deheerst and lardef like this.
  2. lardef
    Cupcake Jun 8, 2018
    lardef , Jun 8, 2018 :
    I have exactly the same issue with my op6 5.1.5 and using forticlient. I am disconnected just after the connection.
  3. F_Terence_Quah_gSCv
    Ice Cream Sandwich Jun 8, 2018
    F_Terence_Quah_gSCv , Jun 8, 2018 :
    VPN, is not totally free in the first place.
    (You download stuff with data=use own data, next you connected to VPN, you download= you using own data+VPN company also using their data as well.)
    etc. You download 100mb thing via VPN(it's 100mb on you + VPN company 100mb=200mb total (you pay your 100mb while VPN company pays the other 100mb)
    Lenient one will let u download stuff on them especially big company with hefty bandwidth. However Stricter one will dc you when u download things or bypass certain speed/limit impose (hidden from you/told you in their agreement)
  4. deheerst
    Cupcake Jun 12, 2018
    deheerst , Jun 12, 2018 :
    Same issue here.
    I can connect the OP6 to my VPN server, but it disconnects within a minute or so.
    Tested on both Unifi VPN on USG and Synology (2 different servers) and can confirm this behaviour.
    Also tested a huawei P10 with the same android version and it does not have this issue.
    Also iPhone 6 connects and stays connected.
    So this is most certainly an OP6 issue.
    L2tp ipsec, OP6 android 8.1, oxygen 5.1.6.
    It has nothing to do with paid or free vpn company by the way.
    Funny thing is that my Bitdefender VPN does work, but I need to connect to my office network by VPN.
    hahayan likes this.
  5. deheerst
    Cupcake Jun 16, 2018
    deheerst , Jun 16, 2018 :
    Oxygen 5.1.7 issue persists. Still l2tp IPsec vpn disconnects after 1 minute.
    Advise from OP is to clear cache and if that doesn't help to factory reset. Didn't help here, still facing this bug.
  6. xer0w
    Froyo Jun 16, 2018
    xer0w , Jun 16, 2018 :
    Hi,
    I can also confirm 5.1.7 doesn't fix for me either, wasn't expecting it to tbh as it was mainly to address the Bootloader vuln.
    Hopefully 5.1.8 will have a fix. OP are aware of this bug report btw.
    I'm not going to factory reset as I'm sure this is an OOS bug from my testing, and a reset would be a waste of a lot of my time.
    deheerst likes this.
  7. deheerst
    Cupcake Jun 19, 2018
    deheerst , Jun 19, 2018 :
    I can confirm the issue still exists in version 5.1.8. Tried both USG and Synology, disconnects after 1minute 34 seconds.
  8. xer0w
    Froyo Jun 19, 2018
  9. L1530421170693
    Cupcake Jul 1, 2018
  10. atomaka
    Cupcake Jul 6, 2018
  11. G_Anthony_Ciuffini_pCWS
    Donut Aug 26, 2018
  12. xer0w
    Froyo Aug 26, 2018
  13. baadnewz
    Froyo Sep 22, 2018
    baadnewz , Sep 22, 2018 :
    And it's back on open beta 1 2 3. Ipsec PSK VPN. As soon as screen is off it disconnects from vpn
  14. michaelbar
    Cupcake Sep 29, 2018
  15. xer0w
    Froyo Sep 29, 2018
  16. hahayan
    Donut Oct 18, 2018
  17. peterkeuter
    Cupcake Oct 19, 2018
    peterkeuter , Oct 19, 2018 :
    Same here. It works for about 90 seconds every time, then disconnects. Doesn't matter if the screen is on or off. OP6 latest update (Pie).
  18. hahayan
    Donut Oct 20, 2018
  19. xer0w
    Froyo Oct 20, 2018
    xer0w , Oct 20, 2018 :
    No resolution yet, I've been asked by support to run some tests and logs, but I don't have time to test something they must surely already know how to fix!
  20. hahayan
    Donut Oct 20, 2018
    hahayan , Oct 20, 2018 :
    I submitted the logs, but they did not give me any test...wonder what sort of test ? mind to share? thxxx
