Connectivity Issue with WiFi, LTE, and Bluetooth
  1. FBItalian11
    Eclair Jun 28, 2017
    FBItalian11 , Jun 28, 2017 :
    These might all be separate issues but maybe not. Love to hear your thoughts...
    #1 I notice that when I open WAZE app when I am in my driveway (still on my Wifi) the app will lose network connection once I leave my house (going to LTE). I have to close my app and then reopen it to have it pick up the connection again.
    #2 I have an app called E-Control which lets me control an IR blaster in my house. Normally I can control the device from ANYWHERE. Now I can only control it is I am on WiFi. When I am on my Mobile Network it just says "Initiating Network" and then says "No Connectivity". That wasn't an issue with my OPO
    #3 It takes my car a while to pick up the bluetooth. I have to restart it on my phone a few times in order to get them to connect. It will but it take a few attempts.
    In another thread, someone suggested I call TMobile and have them change my APN Profile? I am thinking that might be a fix to #1 and MAYBE #2. I am not sure if I need to ask them to set the APN to any specific setting though.
    thanks for the help ahead of time.
  2. FBItalian11
    Eclair Jun 28, 2017
  3. KRzYamaneko
    Cupcake Jun 28, 2017
  4. FBItalian11
    Eclair Jun 28, 2017
    I am at work so I can't really mess with it just yet. Hopefully its something they can fix with an update. I am sure it is.
  5. KRzYamaneko
  6. FBItalian11
    Eclair Jun 28, 2017
    well if we keep making posts about it then they are more likely to take notice. Im sure this community wont let something like that go quietly
    Uranium_Ayush likes this.
  7. psid4life
    psid4life , Jun 28, 2017 :
    I had the WiFi issue and I contacted customer services. They said that they were aware of this problem and a fix had already been put out in the form of an update. Sure enough I checked and the update was available so I updated and so far so good. WiFi seems to be working well.
  8. Aemkai
    Froyo Jun 28, 2017
    Aemkai , Jun 28, 2017 :
    I have the same issue with Bluetooth and my car. The phone will connect, then disconnect and them connect again. I have to wait for a few minutes before I can play any music. If I start to play music straight away the phone will disconnect from Bluetooth.
    Glad it's not just me then. Should be rectified via a software update hopefully.
  9. FBItalian11
    Eclair Jun 28, 2017
    definitely. I think its something that should be in an update pretty soon. Seems like they are hitting a lot of these connectivity issues with these first updates
  10. Markoboluo
    Donut Jun 29, 2017
    Markoboluo , Jun 29, 2017 :
    I am also experiencing connecting issue. all the apps works fine with WiFi, but only three apps cannot connecting the 4G LTE network from T-mobile. I tried to reinstall the app and restart the phone but wont work. all the other apps works fine, i can watch youtube video with 4g network, browsing the internet.
    these are the list of app:
    #1 wechat app, cannot connect with 4g network, but can connect with wifi. error info provided in the app says (无法连接服务器(1,-10087)请检查网络)
    #2 PockemonGo, same problem as above, I can only catch pockemons at home using wifi which is sad.
  11. FBItalian11
    Eclair Jun 29, 2017
    FBItalian11 , Jun 29, 2017 :
    This is from the OTA Thread... I did this and it fixed the exact issues you are talking about...
    Settings > SIM & network settings> Click on the sim card that is active... change them to the settings above
    jasonarima likes this.
  12. Markoboluo
    Donut Jun 29, 2017
    still not working.
  13. cherry.sai520
    Donut Jun 29, 2017
    cherry.sai520 , Jun 29, 2017 :
    I brought Oneplus 5 2 days back. I got Oxygen 4.5.3 update and when I was trying to download it, It downloaded 100% but not able to complete and install. update size is about 160mb. Any clue ?
  14. zabihjan
    Honeycomb Jun 29, 2017
    zabihjan , Jun 29, 2017 :
    Waze I use every day no issues from WiFi to 4g. You could Enable aggressive WiFi to mobile handover settings plus mobile data always active under developer options
    I have not manually restarted my phone since I have it
    Bluetooth connection depends on the version of Bluetooth your car Bluetooth is on. It connects instantly on my 2012 Toyota Prius
    Ir blaster issue may not be compatible with 7.1.1
  15. psid4life
    Cupcake Jun 29, 2017
    psid4life , Jun 29, 2017 :
    Just reporting back after installing the update. still having occasional unresponsive WiFi issues. sometimes my SMS takes a while to go through too. think there's more work to be done by the software team.
  16. FBItalian11
    Eclair Jun 29, 2017
  17. FBItalian11
    Eclair Jun 29, 2017
    I already got it fixed. It was the APN issue that they discuss in the newest OTA thread. I manually set up an APN and it was all fixed from there for me.
  18. Markoboluo
    Donut Jun 29, 2017
    yes
  19. Markoboluo
    Donut Jul 4, 2017
    Markoboluo , Jul 4, 2017 :
    i tried several times your solution and i dont know what happened it just worked. thank you ~
  20. R1544587423188
    Cupcake Jan 22, 2019
    R1544587423188 , Jan 22, 2019 :
    even I face issue while playing PUBG the down link speed drops to a few kbps if I watch some videos or other stuff it works perfectly
