Contacts being deleted by their own
  1. G_Eugeniu_Goncearuc_ECuE
    Cupcake Aug 13, 2020
    G_Eugeniu_Goncearuc_ECuE , Aug 13, 2020 :
    Greetings,
    I have the following issue with my phone:
    1. Contacts are being deleted by their own, which is happening with granularity.
    1.1 Firstly numbers are getting removed.
    1.2 After Names from contacts disappear.
    1.3 In final contacts from all sync apps are being deleted.
    2. Something is wrong, do you have any suggestions regarding this issue?
    P.S: I would be ready also to rewrite soft from scratch and to downgrade version from OnePlus to the basic one, just to remediate this issue.
    Regards,
    Eugeniu!
  2. Swatiranjan
    Jelly Bean Aug 13, 2020
    Swatiranjan , Aug 13, 2020 :
    Is your Google contact synchronised ?? If so, you should log in with Google and get it synched.
    You'll get all your contacts.
    If you have saved the no.s in SIM, and you changed your phone, SIM contacts ( Max 250) should be there. If you have saved contacts in your previous phone ( in phone only with our Google synchronised), then they have to be transferred to Google contact
    If you removed contacts from other smartphone with same Google account, it'll remove from all devices synchronised with it.
  3. G_Eugeniu_Goncearuc_ECuE
    Hi Swatiranjan,
    My contacts gets synced, I'm using OnePlus for 2 years, issue popped in 6 months ago.
    Contacts weren't touched by me, I just waked up today and half of the contacts weren't present on the phone and even on Google.
  4. Swatiranjan
