Contacts issue via OnePlus 8T
  1. thirumalaiyarun
    Eclair May 3, 2021
    Caoimhín likes this.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 3, 2021
    Tokolozi likes this.
  3. thirumalaiyarun
    Eclair May 12, 2021
  4. thirumalaiyarun
    Eclair May 12, 2021
  5. Caomhin
    OnePlus 9 Series Expert Community Expert May 12, 2021
    Caomhin , via OnePlus 9 Pro , May 12, 2021 :
    Ok, try in the Phone App, check the image below. You can create New Contact.
  6. Caomhin
    Not sure what you are trying to do. At the top it states Save To. Where do you want to save it?
    The phone comes with the Google Comms suite. Contacts is part of that. But it allows you to choose where you want to save the contact at the top of the app.
  7. thirumalaiyarun
    Eclair May 12, 2021
  8. Caomhin
    thirumalaiyarun likes this.
  9. thirumalaiyarun
    Eclair May 12, 2021
    thirumalaiyarun , via OnePlus 8T , May 12, 2021 :
    Yeah you are right. In where do you want to save contact section it will show our Google account and device. For me only Google account is showing. Device option is not visible and not showing. This problem is not from the beginning. For the past fews days only I'm facing this problem
  10. thirumalaiyarun
    Eclair May 12, 2021
  11. Caomhin
    Backup your Contacts and call logs.
    Then clear the Contacts App info Cache and App info Storage.
    Do the same for the Phone Dialler App.
    Open contacts allow any and all permissions required for each app and check if it gives device as an option.
  12. thirumalaiyarun
    Eclair May 12, 2021
    I can't understand the last point which u are are trying to convey
  13. thirumalaiyarun
    Eclair May 12, 2021
    Can you tell me clearly how to do that exactly?
  14. Caomhin
    In each of the apps I mentioned the Google Phone Dialler App, backup the call logs. And the Google Contacts app, backup the Contacts.
    Go into the App info of each app and clear both the Cache and Storage data. This will reset both apps.
    Once done. When you reopen those apps they may ask for permissions such as storage and so on.
    Once you have restored your contacts and calls logs, try and create a New Contact and see if Device is now an option to Save to.
  15. thirumalaiyarun
    Eclair May 12, 2021
    I tried what you had said. But still I didn't get it :(. I think I have to flash the mobile once
  16. Caomhin
    I currently use the following Google Phone version on my phone. Its a Beta version and works well. Might be worth a try.
    https://www.apkmirror.com/apk/googl...e-phone-65-0-370544174-publicbeta-go-release/
    And I also use this version of Google Contacts.
    https://www.apkmirror.com/apk/googl...acts-3-44-2-369776217-2-android-apk-download/
    If these don't fix it. Try the following as well.
    One more thing to try is to reset permissions. But this happens for all apps. But might fix the issue. No guarantee.
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions for all your Apps again.
    Check if this can help.
  17. thirumalaiyarun
    Eclair May 12, 2021
    Okay I will try it and will let you know. I'm using both Google Phone dialer and OnePlus phone dialer too
  18. Caomhin
    Don't have the OnePlus Dialler on the 9 Pro, actually used Google Dialler and Contacts on the 6T when I had it going.
  19. thirumalaiyarun
    Eclair May 12, 2021
    Mine is OnePlus 8t. I will try this
  20. thirumalaiyarun
    Eclair May 14, 2021
    thirumalaiyarun , via OnePlus 8T , May 14, 2021 :
    I tried all the way . It's not showing. Better I will flash the mobile once
