5
Contacts photo not clear via OnePlus 7T Pro
  1. G_Chandan_Rath_PuoP , via OnePlus 7T Pro , Oct 14, 2019 :
    I just got OnePlus 7t pro. No matter how much clearer photos I set for a contact, it always gets blurry. I think there is some problem in it's algorithm. Can anyone guide a fix!
    It's not such big an issue but it's an issue!
  2. Hemant_Dhiman
    Donut Oct 14, 2019
    G_Chandan_Rath_PuoP likes this.
  3. sudamSreenath
    Donut Oct 15, 2019
  4. pablofg1978
    Spanish POC Assistant Head Moderator Oct 15, 2019
    pablofg1978 , Oct 15, 2019 :
    Maybe is because the contact app compresses the contact image.
    You can use the feedback page to submit your issue directly to OnePlus
    Https://forums.oneplus.com/feedback
  5. #5
  6. pablofg1978
    Spanish POC Assistant Head Moderator Oct 17, 2019
    pablofg1978 , Oct 17, 2019 :
    Copy the link and open it in a web browser
  7. Dragovic
    Cupcake Oct 17, 2019
    Dragovic , Oct 17, 2019 :
    I found a work around for this, I thought I was the only one having this issue xD
    As simple as it is, download Google Contacts from playstore, and open the contact in Google Contacts app, let the image download.
    once it's done, check the same contact in OnePlus Contacts app, it must be fixed and not blurry by now
    Do this for every contact having blurred image.
    Cheers
  8. abhik_44
    Donut Oct 18, 2019
  9. G_Chandan_Rath_PuoP , via OnePlus 7T Pro , Oct 19, 2019 :
    Yup, it did work, thanks alot.[e]1f609[/e]
  10. Manojkum ar Pawar
    Cupcake Oct 20, 2019
    Manojkum ar Pawar , Oct 20, 2019 :
    Even Google contacts show blurred contact photos, but I can see perfectly sharp pictures on my old Oneplus which has its contacts synced to Google. I transferred contacts using Oneplus switch though, could that be the issue?
  11. Dragovic
    Dragovic , Oct 20, 2019 :
    I think that might be it, I also transferred the data via switch but the fix I mentioned worked.
    Make sure you stop syncing up the contacts from new phone by Google, then delete all of them, backup the contacts from previous phone (one having the sharp contact images) and then finally turning the sync on for new device. I did the same and it worked.
    Hope that helps
  12. G_Chandan_Rath_PuoP , via OnePlus 7T Pro , Nov 6, 2019 :
    Completely agreed!
  13. ADARSHVG9
    Eclair Nov 8, 2019
  14. sivarajane
    Gingerbread Nov 8, 2019
    sivarajane , via OnePlus 7T Pro , Nov 8, 2019 :
    Use the Google contacts app from the playstore... And try refreshing the photos in Google contacts. It will refresh the default contact app pics... This Worked for me
    G_Adarsh_Vg_yfcS likes this.
  15. ADARSHVG9
    Eclair Nov 8, 2019
    ADARSHVG9 , via OnePlus 7T Pro , Nov 8, 2019 :
    thank u bro.. it's worked[e]1f60d[/e]
    sivarajane likes this.
