4
contacts problem
  1. knpatel1991
    Donut Jan 26, 2017
    knpatel1991 , Jan 26, 2017 :
    After upgrading to newer version I am not able to find all of contacts, some of the contents are not displaying when we search it however they are all ready saves in the device.
    please have some attention.
    thank you
  2. yka1988
    Froyo Jan 26, 2017
    yka1988 , Jan 26, 2017 :
    a few ideas:
    check your contact apps permissions. go to settings/apps, find the contacts app and check the permissions.
    since you mentioned "some don't show", also check the app settings itself. so open the contacts app, hit the menu button at the top right and select "settings". there should be an option saying "display contacts" or similar, where you can set which contacts should be displayed in the app in general.
  3. shiva.boluguri
    Cupcake Jan 26, 2017
  4. G_Kavita_Prajapati_PXQT
    Cupcake Jan 27, 2017
  5. G_Kavita_Prajapati_PXQT
  6. G_Balu_Balajinaik_SxYl
  7. john3293
    Jelly Bean Jan 27, 2017
    john3293 , Jan 27, 2017 :
    For each and everyone of you... I had faced the same issue. Tried everything I could do.
    At last, reset the phone without wiping the internal storage. Now everything is working fine. :)
    SxYl, post: 15692841, member: 983981"]you talking about Android 7 update??[/QUOTE]
  8. Thibaut van Kerckhoven
  9. G_Rishabh_Arora_bPWN
  10. Kiran.a.joseph
    Kiran.a.joseph , Jan 27, 2017 :
    Try deleting the data and cache of the phone app from settings => apps => phone => storage
    Then force close the phone app from settings => apps => phone
    Try contacts sync from Google account. If this dosent work, try removing and adding the Google account and then sync the contacts from Google.
    Sun90 likes this.
  11. malriswan
    Eclair Jan 27, 2017
  12. Thibaut van Kerckhoven
  13. wospino
    Ice Cream Sandwich Jan 28, 2017
  14. zakwithu
    Cupcake Jan 28, 2017
  15. Mihir Khakhar
    Cupcake Feb 19, 2017
    Mihir Khakhar , Feb 19, 2017 :
    I am having similar issues.. Contacts arent showing on search or in the contacts app. But when i receive a call it displays the name.
    G_Rudy_Ramsawak_IqUl likes this.
  16. G_Ευθύβουλος_
  17. creatordinkar
    creatordinkar , Feb 19, 2017 :
    If you did it before system sync restore schedule than this may occur. Remember to manually sync while updating and factory reset
  18. xcrm
    Ice Cream Sandwich Feb 19, 2017
    xcrm , Feb 19, 2017 :
    Think before you start.
    For the next time, make an export of the contacts. Save them on a computer. If you have problems after update, import the contacts. It's very simpel.
  19. afzal.m
    Cupcake May 14, 2017
  20. amin_disoza
    Cupcake Jul 19, 2017
