3
Convert T-Mobile OnePlus 7 Pro to International (Unlock) firmware!!
  1. S1558388618694
    Gingerbread Aug 6, 2019
    S1558388618694 , Aug 6, 2019 :
    Last night, I was able to convert my T-Mobile OnePlus 7 Pro to the exact same firmware that you would get if you buy the OnePlus 7 Pro unlocked from OnePlus. It's so amazing & even faster than before. No more T-Mobile Bloatware (only two were there, but can simply uninstall like any other app), the pink boot up screen you would get when you turn off or turn on is no longer present!! AND you get the latest software updates immediately from OnePlus directly, instead of T-Mobile. If you want to do this too, I highly recommend it. It is very very stable.
    The download link/steps are on "XDA Developers" website or just type on YouTube. This isn't the first time you can do this, it was possible on last year's OnePlus 6T. I'm now on the latest 9.5.11 of Oxygen OS on the T-Mobile OnePlus 7 Pro. It is completely safe, however it won't require you to have your device or bootloader unlocked. Just remember that when after you launch the program "Msm Download Tool" once you have all the necessary files together & extracted in one folder, hold on both volume buttons while the device is off completely & plug in your charging cable & again hold the volume buttons again & press "Start" shown on the program immediately when you see your device is connected". You'll see a green progress bar.
    Hope this helps.
  2. jtec99
    Eclair Aug 7, 2019
    jtec99 , Aug 7, 2019 :
    Has anyone had issues with the downloads not being extractable? that's all I keep getting. the computer treats them as if they're either unknown or. exe files.
  3. S1558388618694
    Gingerbread Aug 8, 2019
    S1558388618694 , Aug 8, 2019 :
    I had issues, but I was able to extract them after downloading a zip file app, then it worked!! You will know everything is extracted when you see TWO of the "MSM Download Tool" program/file.
    J1541473814919 likes this.
  4. jtec99
    Eclair Aug 8, 2019
    jtec99 , Aug 8, 2019 :
    Ok thank you. I'll try that next. appreciate the input.
    S1558388618694 likes this.
  5. sonnyhaze
    Froyo Sep 1, 2019
    sonnyhaze , Sep 1, 2019 :
    Last night I converted my Oneplus 6T (T-Mobile Version) to the McLaren international version. I too have a Oneplus 7 Pro. I plan to do the same. Any new updates or advice?
  6. S1558388618694
    Gingerbread Sep 4, 2019
    S1558388618694 , Sep 4, 2019 :
    That's awesome!! My advice to u when you do it on your OnePlus 7 Pro is make sure you have all 3 correct drivers extracted into the same folder & back up your device. it's really a very easy process!! Enjoy!!!
  7. sonnyhaze
    Froyo Sep 4, 2019
    sonnyhaze , Sep 4, 2019 :
    Yeah it was very easy installing drivers. The drivers are built into the phone. Ya see ehen you plug it into your computer. your computer will recognize your phone. By going to windows explorer you will see the phone show up under "this PC". If you click on it the OnePlus USB Drivers are there to install...
    Max_Coraza likes this.
  8. ShaL1m
    Eclair Sep 4, 2019
    ShaL1m , Sep 4, 2019 :
    This is cool but where can you download the T-Mobile original stock firmware if you decide to roll back?
  9. Ian_Mullins_1976
    Cupcake Sep 5, 2019
    Ian_Mullins_1976 , Sep 5, 2019 :
    I did this back in June and had no issues until last night when I loaded the new Android 10 open Beta. After I loaded it, the phone was then in a network lock out. I ended up having to put the T-Mobile version back on in order to get it unlocked. I needed to anyway because I'm paying my phone off this week and I'm not certain they could have unlocked it with that firmware on it. Just letting you know what may happen.
  10. ShaL1m
    Eclair Sep 5, 2019
    ShaL1m , Sep 5, 2019 :
    but how did you revert back to TMobile stock from global firmware? I can't find a download to the T-Mobile variant stock.
  11. ShaL1m
    Eclair Sep 5, 2019
    same thing happened to me, when I flashed to global the network was fine then when I updated it to the Android 10 it went on network lock mode.....then I did a full downgrade back to Android Pie now the network works...but I need the T-Mobile stock rom for the Oneplus 7pro, if anyone has a link please comment.
  12. jtec99
    Eclair Sep 5, 2019
    jtec99 , Sep 5, 2019 :
    I still can't get the conversion to international working. think an old laptop would be the reason? I'm talking 2007 old
  13. S1558388618694
    Gingerbread Sep 5, 2019
    S1558388618694 , Sep 5, 2019 :
    The Android 10 that's right now available for OnePlus 7 Pro is a beta & ONLY for OnePlus 7 Pro devices either unlocked from T-Mobile or purchased from OnePlus website. I just learned about this too. I had to revert back to Pie just to use my phone again.
    if you want to go back to Stock T-Mobile firmware from the international firmware, just simply type YouTube channel "Gadget Beard" he did a video of going back & the video is pretty much the same as the international firmware which he did already, but he did provide the links to the stock firmware for T-Mobile.
  14. D1570819532172
    Cupcake Oct 11, 2019
    D1570819532172 , Oct 11, 2019 :
    Does this unlock your phone? I bought one from a guy and he told me that it was unlocked when I went to check it it wasn't. It's not reported or anything it's just not unlocked. And the app doesn't let me unlock it.
  15. S1558388618694
    Gingerbread Oct 11, 2019
    S1558388618694 , via OnePlus 7 Pro , Oct 11, 2019 :
    There's a another method which is the exact same process.
  16. Mildromeda
    Gingerbread Oct 15, 2019
    Mildromeda , via OnePlus 7 Pro T-Mobile , Oct 15, 2019 :
    ok need some help here hopefully someone smarter than me can help, I recently unlocked my OnePlus 7pro from T-Mobile after 4 months. I also removed it from T-Mobile and went to straight talk believe it or not alot better, anyway I'm trying to convert to the international version or which ever will allow me to update to latest TMobile is painfully slow here. So I got adb running and downloaded all the files from xda but for some reason my phone won't recognize in adb... so I've tried debugging and I've installed the drivers from OnePlus application after plugging in the phone even tried the whole "update drivers" in Windows and it says it's unable to find the drivers.
    can someone please rescue me from the death grip that is TMobile I will never be that impatient for a phone again.
  17. S1558388618694
    Gingerbread Oct 16, 2019
    S1558388618694 , via OnePlus 7 Pro , Oct 16, 2019 :
    Here is the video that I used to rebrand my TMobile OnePlus 7 Pro to international firmware.
    The device driver's, you can get them from XDA developers which is also in the video. When you get to adb. type "adb devices" & make sure your phone is connected to the computer.
    Make sure you're using a Windows PC/laptop, not a Mac.
    Once you have all the files to convert, you will know you're ready when you see TWO of the MSMTOOL program in the same folder.
    When you do get the program running, uncheck the SHA256 Icon.
    Here is the link/video turtorial.
    Since you're now using straight talk as your Carrier. The firmware is still exactly TMobile before you convert.
  18. sonnyhaze
    Froyo Oct 16, 2019
  19. sonnyhaze
    Froyo Oct 16, 2019
    sonnyhaze , via OnePlus 7 Pro , Oct 16, 2019 :
    still need help with T-Mobile stock rom? I had a T-Mobile version and converted it to international. well about a month later my phone lock was turned on which wouldn't allow me to use my second sim. so I reverted back to TMobile made sure to completely unlock it. then I converted it to international for the last time I hope. so if you still need TMobile stock rom let me know
    ShaL1m and S1558388618694 like this.
  20. sonnyhaze
    Froyo Oct 16, 2019
    I assume you clicked on settings>about and clicked on build 7 times. Then go to settings>settings>developer mode and enable usb debugging. if all you drivers are correct the last thing you'll need to do once plugged in is pull down the status menu and click on Android system and change it from charging to file transfer. see if that works.
