Correct pin shows as wrong pin - had to hard reset via OnePlus 9 Pro
  1. S1620796290848
    Cupcake Oct 22, 2021
    S1620796290848 , via OnePlus 9 Pro , Oct 22, 2021 :
    My phone suddenly froze and I thought a restart would help. But after restart the phone dir not accept my pin( the correct one), I had to factory reset it. any tips to get back all memory now??
    Also pls look into the issue as well??
  2. Gor.
    Lollipop Oct 22, 2021
    Gor. , Oct 22, 2021 :
    Hey there.
    I'm afraid but it's quite difficult to recover lost data especially if you didn't backup. Check out the following advise if you had synced with a Google account.
    You can also check out the following link and see if it helps. Kindly read the article and the steps mentioned carefully.
    https://recoverit.wondershare.com/phone-recovery/recover-photos-after-factory-reset-android.html
  3. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Oct 22, 2021
    Caomhin likes this.
