16
COS 12.1 YOG4PAS2QL update
  1. pritambhadane
    Gingerbread Oct 18, 2015
    pritambhadane , Oct 18, 2015 :
    @samirspatil can you please confirmed that the third party font installation bug is solved or not
  2. janguv
    Honeycomb Oct 18, 2015
    janguv , Oct 18, 2015 :
    Isn't that an Android-wide security measure, rather than a bug?
  3. Mecca EL
    Mecca EL , Oct 18, 2015 :
    For those having trouble installing the incremental...
    I downloaded and extracted the contents, then moved them to folder with the same name as the zip. I deleted the zip. Then I re-signed the folder I made with this app: https://play.google.com/store/apps/details?id=zip.me&hl=en
    I did all of this on device.
    Rebooted to recovery, and installed with no errors. Hope this helps.
  4. Lucky7777
    Eclair Oct 18, 2015
    Lucky7777 , Oct 18, 2015 :
    Hello Been fallowing this post but have not read anywhere if this update is any good ... I figure from the size its just a security update ?
  5. pepsy89
  6. okak24
  7. okak24
    okak24 , Oct 18, 2015 :
    Can you explain all steps please? I do this but not update. After i created folder and do this. In signed zip created show meta-info folder and sdcard folder, inside sdcard folder is download folder and inside this is cm12.1 folder i created and inside this folder is what i need. I think is to many folders. Can you explain please? And sorry my English
  8. captsakis
  9. aleb91
  10. Aary4u
    Froyo Oct 18, 2015
    Aary4u , Oct 18, 2015 :
    I'm on the latest cos12.1 update. How to get rid of 'get now cards' shit from the home screen.
  11. nicerous
  12. B92
  13. ibrahim52
    ibrahim52 , Oct 18, 2015 :
    Guys can anyone confirm if the incremental update is working through TWRP because the full update is not SIGNED zip and I don't want to take any risk ;(
  14. MR.BRIGHTSIDE
    Eclair Oct 18, 2015
  15. pritambhadane
    Will you please confirm if the third party font installation bug is resolved or not in this latest OTA
  16. Cvecko90
    Froyo Oct 18, 2015
    Cvecko90 , Oct 18, 2015 :
    Thank you so much man
    UngIued likes this.
  17. ibrahim52
  18. pepsy89
    pepsy89 , Oct 18, 2015 :
    HOW I INSTAL IT VIA TWRP ? It's so hard someone to answer :| ? :)
    "Best" Comunity ever !
    ibrahim52 likes this.
  19. Mecca EL
    Sure.
    You should have a total of five main files. Create a new folder for these and rename the folder. Then use the ZipMe app to sign.
    I used Philz Recovery to install, because TWRP has been buggy lately
  20. pepsy89
    @Mecca EL why you don't upload the file that you made for us ? :)
    That will help us a lot , and you allready have the update file. Can you do that ?
    deviantartjr and Mecca EL like this.
