16
COS 12.1 YOG4PAS2QL update
  1. Deactivated User
    Oct 18, 2015
  2. i5xswipe
    Ice Cream Sandwich Oct 18, 2015
    i5xswipe , Oct 18, 2015 :
    The incremental works fine with stock recovery. If you are using TWRP, you likely need to wait for TWRP to update for compatibility, no fault of Cyanogen.
  3. Deactivated User
    Oct 18, 2015
  4. pepsy89
    Honeycomb Oct 18, 2015
    pepsy89 , Oct 18, 2015 :
    Ok guys , this is available for the those who have TWRP instaled.
    1. BACKUP with twrp.
    2. Complete wipe.
    3. Instal cm-12.1-YOG4PAS2QL-bacon
    4. Restore Data ONLY from the backup.
    5. Restart
    6. Thanx to Setting.Out from XDA.
    Make Backup , Complete wipe, flash everything then select restore and ONLY restore data.. Everything will be as if you dirty flashed.. i hope so :D
    Jorge48197 likes this.
  5. okak24
    Gingerbread Oct 18, 2015
    okak24 , Oct 18, 2015 :
    OK this i understand. But after this in zipme what select for create? Folder? File? Or what? If i select folder and go to folder where i put 5 files. And i want add meta-info, i select but open meta-info. Not select. In patch folder is the same thing. Only others 3 files i can select and add. In folders not select but open. Do you understand me? Sorry my English. Is here i need help. Thanks
  6. aleoje
    Cupcake Oct 18, 2015
    aleoje , Oct 18, 2015 :
    Thanks brother, that worked for me. :)
  7. jjrojoc
    Froyo Oct 18, 2015
    jjrojoc , Oct 18, 2015 :
    Correct, i did it muy self this morning, working nicely
  8. pepsy89
    Np , worked for me to , but i can't instal xposed don't know why, when i flash xposed, the android remains stucked on cyanogen locked screen.
  9. 2ASIAN4U Studios
    Eclair Oct 19, 2015
    2ASIAN4U Studios , Oct 19, 2015 :
    Welp, I screwed that up...
    I accidentally cleaned out all of the internal storage and lost the TWRP backups I had. Downloading the zip again so I can clean flash the darn thing. Complete fail on my part. Hope I remember what apps I had...
  10. Crosswind
    Froyo Oct 19, 2015
    Crosswind , Oct 19, 2015 :
    Don't worry dude. Google knows and even let's you pick which ones you wanna install during the setup process!
  11. MR.BRIGHTSIDE
    Eclair Oct 19, 2015
    MR.BRIGHTSIDE , Oct 19, 2015 :
    Just dirty flash..
    Anybody know how to show battery percentage on the top right screen?
  12. UngIued
    Honeycomb Oct 19, 2015
    UngIued , Oct 19, 2015 :
    Settings > status bar, move clock to center, left, or hidden and that will move battery to the right.
    Edit : if you don't have status bar in settings.
    Go to settings > about phone > advanced mode and switch it on and it should be there.
    MR.BRIGHTSIDE likes this.
  13. mlord
    Gingerbread Oct 19, 2015
    mlord , Oct 19, 2015 :
    Older versions of Xposed won't work anymore: Xposed v75 (or newer) is required for this update.
    pepsy89 likes this.
  14. MR.BRIGHTSIDE
    Eclair Oct 19, 2015
    Thanx..it works
    UngIued likes this.
  15. UngIued
  16. jbollaert
    jbollaert , Oct 19, 2015 :
    1 bug is bag on my phone... Wifi disconnect in sleep mode. Wifi advanced settings are on 'never'... A shame...
  17. eja
    Cupcake Oct 19, 2015
    eja , Oct 19, 2015 :
    you can change DPI, just enable "advance mode" option in about phone for advance setting.
    Deactivated User likes this.
  18. Xynoclafe
    Xynoclafe , Oct 19, 2015 :
    Even I have the dev-keys thing, and I had flashed the full zip. The only reason i can think of is that the full zip and the fastboot image are not signed while incremental is. So people who used incremental don't seem to have dev-keys.
  19. nitinparswani
    Froyo Oct 19, 2015
    nitinparswani , Oct 19, 2015 :
    anyone else getting a weird in-call dialer screen after this update? It shows an ugly transparent image in the blue area if there is no contact picture..
  20. Tricksodave
    Jelly Bean Oct 19, 2015
    Tricksodave , Oct 19, 2015 :
    Any ideas what the dev-keys thing is all about?
