16
COS 12.1 YOG4PAS2QL update
  1. captsakis
    Gingerbread Oct 17, 2015
  2. muschiu34bv
    Donut Oct 17, 2015
    muschiu34bv , Oct 17, 2015 :
    How you have update.what method you have use.And if you can explain step by step.Thank You!
    pirata_1985 likes this.
  3. MilesTEG
    MilesTEG , Oct 17, 2015 :
    I'll try with thoses drivers.
  4. --__LoRiS__--
    Donut Oct 17, 2015
    --__LoRiS__-- , Oct 17, 2015 :
    Can you tell me the right option to select? Thanks
  5. Link_of_Hyrule
    Froyo Oct 17, 2015
    Link_of_Hyrule , Oct 17, 2015 :
    Flash stock unroot make sure before you do that to enable no wipe mode in the settings though. Make sure to use the Fastboot zip file.
  6. pirata_1985
    Nougat Oct 17, 2015
    pirata_1985 , Oct 17, 2015 :
    Downloaded the 18mb zip then reboot in cyanogen recovery. Update install from zip. Select the zip file. Install.
    webdevgirl and markini like this.
  7. sequelae
    sequelae , Oct 17, 2015 :
    Update:
    After first failed try, I tried again but first wipe of cache, the install through recovery. Works fine now
  8. --__LoRiS__--
    Donut Oct 17, 2015
    It worked thanks! :)
    Link_of_Hyrule likes this.
  9. Link_of_Hyrule
    Froyo Oct 17, 2015
    What was the error before you wiped the cache?
  10. lsamanl
    Eclair Oct 17, 2015
  11. Crosswind
    Froyo Oct 17, 2015
    cantara256, deviantartjr and lsamanl like this.
  12. markini
    Nougat Oct 17, 2015
  13. rframe
    Froyo Oct 17, 2015
  14. --__LoRiS__--
    Donut Oct 17, 2015
    I have a really BIG BIG problem after update, all advenced options are missing under settings, for example I don't have anymore navring options, no more status bar options to change battery icon etc. etc...
  15. arkadius
    Jelly Bean Oct 17, 2015
    arkadius , Oct 17, 2015 :
    Settings>About phone> Advanced mode You have to turn it on.
  16. atulclassic
    Honeycomb Oct 17, 2015
    atulclassic , Oct 17, 2015 :
    i belive OTAs can be flashed through stock recovery only which in our case is cyanogen recovery
  17. KKoen
    Eclair Oct 17, 2015
    KKoen , Oct 17, 2015 :
    Can't see this option
  18. Ceasedd
    Marshmallow Oct 17, 2015
    webdevgirl likes this.
  19. v0 HaVoK 0v
    Ice Cream Sandwich Oct 17, 2015
    v0 HaVoK 0v , Oct 17, 2015 :
    I have tried to install the incremental, but it fails for me.
    I don't know why it says I'm on 25r (4.4.2) when I'm actually on 1n0 (5.1.1) Screenshot_2015-10-17-06-55-07.png
    Edit: Going to try with the link stevenching shared.
    Edit2: Ok same problem. It says it fails because I'm on 25r when I know I'm definitely on the previous update before this..
    How does this zip detect which version I'm on? I'm trying to figure out how it gets it so so wrong. I'm long past 25r... Anyone know what's this about?
    Akki4Trespasser likes this.
  20. --__LoRiS__--
    Donut Oct 17, 2015
    LOL I'm an idiot!!!
