COS 12.1 - YOG4PAS3JL | Bugs & Discussion Thread
  1. jobykv
    Cupcake Nov 20, 2015
    jobykv , Nov 20, 2015 :
    Same here..after this update HERE is not working..Even Google Maps is not working:(
  2. Scann69
    Honeycomb Nov 20, 2015
    Scann69 , Nov 20, 2015 :
    Did you do a clean flash? Or just upgrade? I was messing with themes....did not face any problem. For camera, i installed the ColorOS camera which you can get from XDA.
  3. yusuf khan
    Eclair Nov 20, 2015
    yusuf khan , Nov 20, 2015 :
    No. I just bought the phone and got the update. I didn't do any clean flash. I don't know why the themes work like that on my phone. Also, is that camera problem hardware or software? If it's hardware I should contact amazon in that case. Same goes for the yellow tint. What should I do for that? Thanks for your help :)
  4. bkr32
    Gingerbread Nov 20, 2015
    bkr32 , Nov 20, 2015 :
    drop down menu and quick settings overflow from the screen in either portrait or landscape, same goes for volume panel, not quite sure whats been triggering it
  5. yusuf khan
    Eclair Nov 21, 2015
  6. CIS23691518
    Donut Nov 21, 2015
    CIS23691518 , Nov 21, 2015 :
    Is anyone else still drooping signal. And if not how do I fix mine my signal is super weak and no one can hear me
  7. morencia
    Froyo Nov 21, 2015
    morencia , Nov 21, 2015 :
    I have tethering problems till I updated to YOG4PAS3JL just the same than this guy from xda: so the problem is serious so I had been in a meeting without any connection for more than 8 hours. Not hotspot not USB not BT internet sharing connection with OPO. It seems it's a problem of connection with this CM version. The computers connect full range and data it's OK in phone so the computer is unable to connect to internet. Anyone can give some light to this?
  8. axbrandao
    Gingerbread Nov 22, 2015
    quaddropop likes this.
  9. naman05
    naman05 , Nov 22, 2015 :
    Download the complete update zip and flash using recovery... Should solve your problem.
  10. naman05
    yusuf khan likes this.
  11. bumptheposts2
    Gingerbread Nov 23, 2015
    bumptheposts2 , Nov 23, 2015 :
    Wifi Tethering works fine for me...
    But i have another issue. The phone cannot get an ip address from my Canon camera. This worked fine before but with the latest version it does not get an IP. Another phone works ok.
  12. zyrppa
    Donut Nov 23, 2015
    zyrppa , Nov 23, 2015 :
    Just flashed via TWRP. No EVERYTHING is stopped/crashed.. play services, trebuchet etc. Reboot doesn't help:mad:
    This is 3rd time when updating messes my phone. I think i'm gonna throw OPO away and start using my good old Samsung xcover 271:D
    PS. used cm-12.1-YOG4PAS3JL-bacon-signed.zip
  13. bumptheposts2
    Gingerbread Nov 24, 2015
    bumptheposts2 , Nov 24, 2015 :
    Did you wipe caches? Sounds like you didn't.... Otherwise wipe data also and strart from scratch. If that also does not help wipe system and flash again. It WILL work
    rahultr likes this.
  14. brockyyyy
    brockyyyy , Nov 24, 2015 :
    Bro, can you post a screen shot. I dont see that in my phone. Am on android 5.1.1 cyanogen os 12.1 YOG4PAS3JL
  15. cosmic
    Ice Cream Sandwich Nov 24, 2015
    cosmic , Nov 24, 2015 :
    might only be visible if you turn on advance settings
  16. jmulla100
    Donut Nov 24, 2015
    jmulla100 , Nov 24, 2015 :
    Anyone have a fix for connecting the opo to the PC? My computer won't detect it and I cant enable USB debugging in the dev menu. This all happened after I chosebthe option to have my SB connection for charging only.
  17. NewBie741
    Cupcake Nov 24, 2015
  18. cosmic
  19. brockyyyy
    Gingerbread Nov 25, 2015
    brockyyyy , Nov 25, 2015 :
    Where do we find those advance settings? Previous version of cyanogen, i had the option in sounds/volume somewhere. not lost it..
  20. da_big_bobert
    Donut Nov 25, 2015
    da_big_bobert , Nov 25, 2015 :
    Anyone else here experiencing phone reboots and reboot loops ANYTIME you try to download something. Whether its a pdf from a website...an app...an app update...or even and OTA update. Phone instantly reboots and either enters a loop or just reboots the once?
