175
COS 12 Master Fix Thread
  1. jstepa KitKat Apr 22, 2016
    jstepa, Apr 22, 2016 :
    How to like this post twice? ;):D
    Dr. Indest and theshinybeast like this.
  2. hardshock333 Cupcake Apr 24, 2016
    jstepa likes this.
  3. Manish166 Cupcake Apr 25, 2016
    Manish166, Apr 25, 2016 :
    my OP1 is also stucked, i dont know its switched on or off, it is vibrating and showing OP logo screen endlessly.
  4. Dr. Indest Lollipop Apr 25, 2016
    Dr. Indest, Apr 25, 2016 :
    That means your data partition is probably messed up. What where you doing before this issue occurred?
  5. cajmere Cupcake Apr 25, 2016
    cajmere, Apr 25, 2016 :
    Hi,
    Last week i updated to COS13 but had troubles, couldn't call or receive/send sms, because i couldn't find a solution i did a downgrade again to cos12.1.1 . Had a factory reset and reconfigured everything without any problems. But i'm facing a problem that a never had before in the past.
    My mobile network is constantly switch from 3g to 3g+ (every couple of seconds it switches) or loses signal, where in the past there was never a problem, always stable connection. If I switch off wifi it can take 5minutes till i've got mobile network.
    I removed my APN and add it again. Switched to 4g, 3g etc. Nothing seems to help.
    Someone has idea how to solve this issue? It's really unusable this way.
    Thank you.
  6. Manish166 Cupcake Apr 26, 2016
    Manish166, Apr 26, 2016 :
    i dont know how it started but i think it got updated then all this started, but i kept trying some basic things like connect it to laptop and charge, then i have done "power button+vol up/down" keys many times, sometimes it get starts and run properly and then again goes to same loop, so finally once when it was working fine i did factory reset, but after that also it went into same loop once or twice....ryt now its running properly but donno till when it will run...but you please tell me what to do when it happens again...
  7. yg211 Gingerbread Apr 27, 2016
    yg211, Apr 27, 2016 :
    @Reboot101 I have wifi issue on cos 12.1.. U have placed a link of a file that can be flashed to fix it. Also, the mobile network signal isnt good. So there's a fix for that too. These issues require flash. Can i flash it using stock recovery? Or do i need to have a custom recovery? My opo is complete stock n i have no intention to unlock bootloader and install custom recovery. Please help
  8. Dr. Indest Lollipop Apr 27, 2016
    Dr. Indest, Apr 27, 2016 :
    You need twrp. :(
  9. yg211 Gingerbread Apr 27, 2016
    Leave the mobile network signal.
    Atleast for the wifi fix can i flash the file using stock recovery?
  10. Dr. Indest Lollipop Apr 27, 2016
    No :(
  11. yg211 Gingerbread Apr 27, 2016
    Ok :(. I shall enter static ip address for time being..
    Is it fixed in the cos 13?
  12. Dr. Indest Lollipop Apr 27, 2016
    It is fixed in CM 13, never tried COS 13.
  13. yg211 Gingerbread Apr 27, 2016
    Hmm.. Thanks for the replies :)
    Dr. Indest likes this.
  14. damagedcdn Cupcake Apr 30, 2016
    damagedcdn, Apr 30, 2016 :
    as anyone experienced the error on the cyan message widget. it just shows loading message no mater how many times you restart the phone or reload the widget?
  15. Dr. Indest Lollipop Apr 30, 2016
    Dr. Indest, Apr 30, 2016 :
    Screenshots plz and what OS, COS 12.1?
  16. damagedcdn Cupcake Apr 30, 2016
  17. Manster10 Cupcake May 1, 2016
    Manster10, May 1, 2016 :
    For those of you who have a glitchy phone due to the updates, all you have to do is Restore/Factory Reset (for some, you have to wipe cache, etc) your phone like you would do on a computer (in the BIOS of the phone). I did this yesterday with CM13 and my phone became anew, with the same version of the OS. I realized I was an idiot. If you're reluctant on losing saved photos and other stuff, I wouldn't know another way.
  18. Orochieddy Cupcake May 1, 2016
    Orochieddy, May 1, 2016 :
    I am having all these issues after updating to 13.0 yesterday. really frustrating. idont know how to downgrade either. not techie
  19. millar Donut May 1, 2016
  20. millar Donut May 1, 2016
    millar, May 1, 2016 :
    Phone has rebooted 3 times since yesterday, last time giving me the option for reboot or factory reset and a couple other options . Remembered what the circle is for.
