13
COS 13.0 Battery Life discussion thread!!
  1. Nikkhil
    Jelly Bean Apr 10, 2016
    Nikkhil , Apr 10, 2016 :
    Hello Folks,
    I personally found that the battery life on my OPO has increased drastically after the COS update [only while on standby] (screenshots provided)
    And the 'Doze' feature functions well enough.
    In this post I have mentioned a few issues and solutions to them. If you have any more issues or alternative solutions you can always qoute this post.
    Here are a few glitches:
    1] The battery stats are buggy (does not show the actual consumption by various apps)
    The problem seems to be solved if you on the latest version.
    Solution:
    a) Wipe the cache partition
    (the option is now present in factory reset in recovery mode)(it takes up to 20mins on some devices)
    (can also be done through settings > storage > clear Cache)
    b) Power off
    c) Charge the battery to 100%
    d) Switch on and it might get solved
    2] Battery drains faster than before while the phone is in use. (SOT is improving after every charge cycle)
    I would like to know your views about the battery life of your OPO after the update and if you have any tips to optimize it further.
    Tips: 1)Please don't install any other battery saver app for 'Doze' to function properly on your phone. If you have done so, just uninstall the app and reboot.
    2) Don't judge the battery life in the first few cycles.
  2. smoins786
    Eclair Apr 10, 2016
    smoins786 , Apr 10, 2016 :
    Even though my WiFi is turned of it is running in the back ground...
    And it is draining my battery very fast ..
    What to do???
    Here is the screen shot
    ShashankPaturkar and ppp999 like this.
  3. jstepa
    KitKat Apr 10, 2016
    jstepa , Apr 10, 2016 :
    Did you turn off wifi scanning?
    Settings, Location, Three dots on the top, analyzing (only option)
    Uncheck Wifi and Bluetooth, these keep the Wifi and Bluetooth always available, if you change settings reboot phone.
  4. imTSS
    KitKat Apr 10, 2016
    imTSS , Apr 10, 2016 :
    Good thread. Most important feature of MM which most were looking fwd to.
    I haven't updated yet. Just observing the feedback from this circus of a forum. Lol
    armmani2001, Taz G, mhab23 and 4 others like this.
  5. Dron99
    Honeycomb Apr 10, 2016
    Dron99 , Apr 10, 2016 :
    Can anyone post pics of Cyanogen Recovery after taking incremental update of COS 13?
    SOT will inform afterwards. Testing*
  6. smoins786
    Eclair Apr 10, 2016
    The WiFi scanning was turned on...
    I turned it off...
    Hope it works..
    Thank you :)
  7. LEQIUX
    Ice Cream Sandwich Apr 10, 2016
    cityguy, Kevin1705, fabish54 and 5 others like this.
  8. niTe_RiDeR_Pro
    niTe_RiDeR_Pro , Apr 10, 2016 :
    What's your SOT & remaining time on battery?
    Please post screenshots.
    Anyways I am not gonna flash it till May, cuz if someone finds any battery drain or any sh**ty bugs & someone makes a master fix thread for cos13 (like the cos12 master fiz thread by @Reboot101), I dont wanna face that again. I already have installed the highly stable Cm13 by @Sultanxda & I am really happy with its battery life & very-very-less-bugs.
    rajaspardeshi likes this.
  9. Abhi.bhandral
    Gingerbread Apr 10, 2016
  10. imTSS
    KitKat Apr 10, 2016
    It's supposed to improve battery life.
  11. ishtiyaaq50
    ishtiyaaq50 , Apr 10, 2016 :
    Both COS and Sultan are based of the same CM stable branch.
  12. Nikkhil
    It optimizes the apps while on standby so as to consume minimum power possible and hence save battery life.
  13. fanatik85
    fanatik85 , Apr 10, 2016 :
    ahahahaha minute 1 goal 1 , was sure about this before it is relased....cyanogen cyanogen cyanogen you wont be anything if you dont inspection custom roms.
  14. a_agarwal
    a_agarwal , Apr 10, 2016 :
    Ha! One of those things that you do and forget... After the factory reset, I had forgotten about this. Thanks.
    jstepa likes this.
  15. laserjet
    laserjet , Apr 10, 2016 :
    Has anyone tried the 'Effiency' battery mode? I'm using it now.
    Less performance, but not so much difference on battery life actually.
    Now at 82% remaining with nearly 1h SOT
  16. niTe_RiDeR_Pro
    I know, but Cyanogen modifies it a lot whereas Sultanxda modifies it only a little & adds the minimal, simple & awesome CAF 3.4 kernel tweaked by @Sultanxda (for a lot of improvements & even better battery life as per his thread in xda), and it is having very good battery life. ☺️
  17. ishtiyaaq50
    What I was trying to say was if they are based on the same branch how can COS 13 have sh**** bugs like you say.Also you are stating the opposite,Cyanogen doesn't modify a lot of the code.Also both ROMs have similar battery life but then again it's your opinion.Over and out.
  18. imTSS
    KitKat Apr 10, 2016
    How much sot were u getting per 10% in cos12.1, so we can compare if there is any improvement ?
    For me it was abt 30mins on an avg.
  19. robin201162
    Froyo Apr 10, 2016
    robin201162 , Apr 10, 2016 :
    Screenshot_20160410-173705.png I was on stock non-rooted cos12.1 when i got my OTA update for marshmallow i did my update at 50% battery only ..will it affect my battery life?
  20. imTSS
    KitKat Apr 10, 2016
    No
    hahaha2223 and robin201162 like this.
