9
COS 13.1 Battery
  1. imTSS
    KitKat Jun 14, 2016
    imTSS , Jun 14, 2016 :
    Pull down the notification bar and select edit tiles. Then swipe to the left most page and turn on show weather
    #41
  2. G_govind_kailas_urhF
    Cupcake Jun 14, 2016
    G_govind_kailas_urhF , Jun 14, 2016 :
    It's enabled
    #42
  3. SureShotWinner
    SureShotWinner , Jun 14, 2016 :
    Same OnePlus White charger with red cable.
    #43
  4. imTSS
    KitKat Jun 14, 2016
    Yes. I am facing the same problem when I tried default launcher. Am using nova. No problem there
    #44
  5. imTSS
    KitKat Jun 14, 2016
    When did you do factory reset last on ur phone?
    #45
  6. SureShotWinner
    #46
  7. kamar.kazi
    Donut Jun 14, 2016
    kamar.kazi , Jun 14, 2016 :
    I think I found the temporary solution to the battery drain well i had to factory reset my opo but u don't have to probably just disable call log backup/restore which is causing the drain from the app settings well it has reduced the battery drain a lot hope it helps. :)
    Update1:the above method only worked for a few hours the android core app battery drain was back finally I did a factory reset again and then let the Skype plug in do its job didn't uninstall it yet now the android core battery stat is just 1% hasn't increased yet the phone is on charge right now will let you know once it's on battery the final result till then stay tuned.
    Update2: well the above thing definitely worked and now by battery stats are back to normal the battery is 80% with an sot of 1 hr 13 m and no android core app in the battery usage screen .....its been 4 hours since i unplugged the charger i know this isnt the solution u expect from cyanogen but till they fix this bug this seems the only option right now :rolleyes::unamused:
    #47
    imTSS likes this.
  8. imTSS
    KitKat Jun 14, 2016
    Not necessary but it refreshes the phone just like a clean install
    #48
  9. Abhishek1994==
    Ice Cream Sandwich Jul 13, 2016
    #49
    Tobikage and imTSS like this.
  10. ndy4eva
    Gingerbread Jul 13, 2016
    ndy4eva , Jul 13, 2016 :
    Does anyone use Google Fit? It seems like my Google Fit is draining the battery on my OPO. I disabled the activity detection on my OPO and the battery life seems to be much (x2) better. I have enabled Google Fit on my Android Wear watch.
    #50
  11. imTSS
    KitKat Jul 14, 2016
    imTSS , Jul 14, 2016 :
    For me it's similar. Getting abt 6.5 hrs sot with more than a day backup.
    #51
    Tobikage likes this.
  12. Abhishek1994==
    Ice Cream Sandwich Jul 14, 2016
    Abhishek1994== , Jul 14, 2016 :
    6.5-7 hrs sot for me.. Going excellent after the update.
    #52
  13. imTSS
    KitKat Jul 14, 2016
    Yes I agree. Quite steady. Easily lasts for 24 hours.
    #53
    Abhishek1994== and Tobikage like this.
  14. F_Danny_Smith_IecM
    Cupcake Jul 14, 2016
    #54
  15. imTSS
    KitKat Jul 14, 2016
    Stats after today's cycle. Screenshot_20160714-212558.png Screenshot_20160714-212607.png
    #55
  16. dhairyarc1
    dhairyarc1 , Jul 14, 2016 :
    seems awsm will flash latest one but one doubt via it boot via multi rom using broken os ? will it support multi rom?
    #56
  17. mant00
    Gingerbread Jul 14, 2016
    mant00 , Jul 14, 2016 :
    Looks good, but since this last update my battery is worst than when I was on ZNH2KAS1KN. I did clean install few days ago via fastboot, the most I am getting is 6 hrs SOT, phone is old 4 months only. Do you turn off wifi over night? Also can you tell me do you have facebook, messenger, instagram, viber and whatsapp installed.
    #57
  18. CasperTFG
    KitKat Jul 14, 2016
    #58
  19. okak24
    Gingerbread Jul 15, 2016
    #59
  20. imTSS
    KitKat Jul 15, 2016
    imTSS , Jul 15, 2016 :
    I have only whatsapp. 6hrs sot is good. Facebook is highly battery consuming
    #60
    mant00 likes this.
