43
COS12 CameraNextMod
  1. abhi08638
    Gingerbread Apr 27, 2015
    abhi08638 , Apr 27, 2015 :
    No, this is a separate app. If you want better lowlight photos, turn the contrast down to 4 or 3 and saturation to 5
    #61
    abechung likes this.
  2. abechung
    Ice Cream Sandwich Apr 28, 2015
    abechung , Apr 28, 2015 :
    Hey, what other settings should I do?
    #62
  3. Madtherapy7
    Honeycomb Apr 28, 2015
    Madtherapy7 , Apr 28, 2015 :
    Abhi is der a separate mode for the 50mp pic.. Like how do I take it ??
    #63
  4. Antastik
    Froyo Apr 28, 2015
    Antastik , Apr 28, 2015 :
    Hello, I would like to report that v5 on cm12.1 has slow and difficult focus in clear image mode, leading to some blurred pictures. Thank you
    #64
  5. abhi08638
    Gingerbread Apr 28, 2015
    abhi08638 , Apr 28, 2015 :
    Set image quality to 100 and that should be enough
    Enable the 50mp option in settings and then change to clear image scene mode to take the picture
    Was it like that on v1? Did you update your rom? Did you try clearing data?
    #65
  6. Antastik
    Froyo Apr 28, 2015
    V1 seemed faster in clear image. I will try to clear data, as you first recommended. By the way, another slight issue remains. When swiping left to the gallery from the camera app, upon swiping back to camera all visual commands disappear, forcing to restart the app.
    Thank you for what you do
    #66
  7. Antastik
    Froyo Apr 28, 2015
    Tried to delete data. Focusing in clear image mode is definitely stuttering compared to auto mode, as well as not always finalized, leading to blurred pictures.
    Just so you know, thank you
    #67
  8. abhi08638
    It's a rom issue. I have no such issues on 5.0.2
    Clear image regular take 6-7 rotations of the circle.
    50mp takes 12-13 rotations.
    Also the buttons come back for when swiping back from the gallery as well
    You'll just have to wait for it to be fixed in the rom.
    #68
  9. abhi08638
    Gingerbread May 25, 2015
    abhi08638 , May 25, 2015 :
    V10
    • scene mode added in settings(not all of them work, let me know which ones do so I can remove the non functional ones)
    • ISO auto is now default
    • autofocus zone added
    • sharpness 4, contrast 4, saturation 6 default
    • skintone enhancement added
    • color effect added
    • red eye reduction added
    • histogram added
    • video stabilization toggle
    • video color effect
    • video HDR toggle
      @BOOTMGR
    • 50MP bugfixes
    • support for vanir/exodus?(Needs testing)
      @infinityplus
    • help with new quickbar with ISO options
    #69
  10. paulissimo
    KitKat May 25, 2015
    paulissimo , May 25, 2015 :
    Thank you, will test try it later ;)
    #70
    abhi08638 and script like this.
  11. Antastik
    Froyo May 26, 2015
    #71
    abhi08638 likes this.
  12. bhaider7
    Froyo May 30, 2015
    bhaider7 , May 30, 2015 :
    I have gone for the black icon to keep it directly identifiable.
    Really great work @abhi08638. I m already using the previous one as my default and now the black icon will b more good.
    There are two circles [configuration icons] on the view finder, one has all the settings and the other one has only the ISO option. is this a feature or a bug?
    #72
  13. SystemofaDan
    Gingerbread May 30, 2015
    #73
  14. megatomic
    Ice Cream Sandwich May 30, 2015
    #74
  15. abhi08638
    Gingerbread May 31, 2015
    abhi08638 , May 31, 2015 :
    Feature, I'm going to add more things so it's easier to access settings
    Mp4
    #75
    SystemofaDan likes this.
  16. redrunnerbeans
    Honeycomb Jun 7, 2015
    redrunnerbeans , Jun 7, 2015 :
    Just testing this. Looks like some great additions to the stock version.
    Have you had much feedback I the histogram... I am not convinced they it is giving me an accurate readings. It would also be useful to have the background of the histogram to be a little smaller and tho have a more transparent background.
    Are folks finding they are getting better results with denoise on our off?
    Thanks.
    #76
  17. abhi08638
    Gingerbread Jun 9, 2015
    abhi08638 , Jun 9, 2015 :
    Histogram isnt really widely used feature so it's not a high priority and as for denoise,
    Daylight is better off
    Night is better on
    #77
    redrunnerbeans likes this.
  18. Slatter191
    Lollipop Jun 9, 2015
    Slatter191 , Jun 9, 2015 :
    @ abhi08638, am running COS 12 17L, .....do I need to uninstall Cynogen mod camera later?
    Got Camera next V10 installed.
    Where would these be located?
    To remove camera sounds
    • go into /system/media/audio/ui
    • delete camera_click.ogg
    • delete camera_focus.ogg
    • delete VideoRecord.ogg
    Thanks!
    #78
  19. abhi08638
    No need to uninstall
    To delete those sounds you need root access and a file broswer to navigate to that directory. I recommend es file explorer
    #79
    Slatter191 likes this.
  20. Slatter191
    Thanks for replying abhi08638,
    My OPO is rooted but again cannot locate> go into /system/media/audio/ui > delete camera_click.ogg > delete camera_focus.ogg > delete VideoRecord.ogg, using ES file explorer or default Cynogen File manager.......any suggestions?
    Generally what are the recommended settings for Camera Next?
    Thanks again.
    #80
