COS12, screen doesn't turn on with incoming calls
  1. kill3r_tadej
    Froyo May 5, 2015
    kill3r_tadej , May 5, 2015 :
    I just install the factory image for COS12. My screen doesn't turn on when I receive incoming calls. The ring tone will play but the screen remain turned off. I want the screen to turn on automatically with the incoming call dialer like kitkat or any other android version. so I can pick up the call. Any one else with this issue? How did you fix it?
  2. SomeSayImHandSome
    May 5, 2015
    SomeSayImHandSome , May 5, 2015 :
    uncheck proximity sensor check in settings
  3. Maquuuu
    Gingerbread May 5, 2015
    Maquuuu , May 5, 2015 :
    I have the same issue and this doesn't fix it. This only leaves the screen on when holding it next to your ear which is a really bad idea.
    It doesn't matter if it's on the table or in my pocket, it never turns on when receiving a call >.<
  4. SomeSayImHandSome
    May 5, 2015
    start from scratch. is all i could tell you
  5. Maquuuu
    Thats not an option for me, I rather settle with having to wake the phone up then :(
  6. SomeSayImHandSome
    May 5, 2015
    why what is the big deal? i don't understand people and phones. they never want to wipe them lol
    Maquuuu likes this.
  7. Deactivated User
    May 5, 2015
  8. kill3r_tadej
    Froyo May 5, 2015
    I did same.
  9. return.of.octobot
    Jelly Bean May 5, 2015
    return.of.octobot , May 5, 2015 :
    Can you elaborate on why it's not an option? If you managed to manually install the factory image, than reflashing shouldn't be too much of a hassle.
    Also, when you say factory image, that implies that you flashed the system files via fastboot, did you wipe your previous OS before doing so?
    I believe the problem you're describing occurs when CM11S modem/radio files are paired with CM12/COS12 operating systems. Is it possible that you didn't flash the COS12 radio files?
    Yeah, exactly what I thought. You can't dirty flash COS12 over CM11 without performing a proper wipe first. The CM11S modem does not play nicely with others, this is what's causing your problems. It's not a bug, you just have remnants of CM11S interfering with the functionality of 12.
    TMess likes this.
  10. Deactivated User
    May 5, 2015
  11. return.of.octobot
    Read my updated post above, the other two I quoted are experiencing the same issues as you because they tried to dirty flash COS12 on top of CM11S without first performing a wipe. You most likely did the same thing.
  12. xtenpeben
    Froyo May 5, 2015
    xtenpeben , May 5, 2015 :
    I find that it takes a while for the screen to turn on. There's got to be a setting somewhere that does this lol.
    I pull it out of my pocket and then 2 seconds later the screen turns on.
    It might not be recognizing that it's already out of the pocket?
  13. blikie
    blikie , May 5, 2015 :
    Yes u can dirty flash over cm11s.
    i have done it and went flawlessly till the battery drain came up recently.
    that bug is probably twrp which steve mentioned about long ago.
  14. SomeSayImHandSome
    May 5, 2015
    oh you dirty flashersssssss. to truth comes out. this is why people have issues ALL the time. WIPE your damn phone lazy bastards
    pbergonzi and return.of.octobot like this.
  15. blikie
    the only issue i have is how Google cant fix a stupid play service drain.
    don't know what ur blabbing about.
  16. SomeSayImHandSome
    May 5, 2015
    that's good for you. go to 5.1.1 nightly and your problem will be fixed. bc google did fix it. idiot
  17. locklear308
    Ice Cream Sandwich May 5, 2015
    locklear308 , May 5, 2015 :
    Well it isn't like windows where you can just move it all to your 2nd SSD :cool:
  18. blikie
    i bet u think of urself as a proud and arrogant ***** *********.
    idiot what if i dont want to go nightlies. thats my choice to make.
    also what if i want to experiment with it. idiot. i have it flashed nandroid but i dont want to go there. idiot.
  19. return.of.octobot
    I'm saying dude, not to get into another debate with you, but this is what I mean when I say that a lot of the 'bugs' people are experiencing with COS12 are a result of shoddy flashing.
  20. SomeSayImHandSome
    May 5, 2015
    but people tell me i am an idiot :D
