cover problem
  1. M1555251636410 Cupcake Jul 16, 2019
    M1555251636410, Jul 16, 2019 :
    corrosion on one plus 5t body....don't know what is the reason. but is there any solution to cover up this or is there any option to change the body cover of phone.???
  2. srinivasan_v Froyo Jul 16, 2019
    M1555251636410 likes this.
  3. M1555251636410 Cupcake Jul 16, 2019
    actually the phone was covered with a phone cover....just removed it and found this patch....it seems like a metal rusting.
  4. B_Wrath Marshmallow Jul 16, 2019
    B_Wrath, Jul 16, 2019 :
    Aluminium doesn't rust. This is abrasion. Rubbing of metal against metal or other hard substances.
  5. Muhsin_Sultan Ice Cream Sandwich Jul 16, 2019
    Muhsin_Sultan, Jul 16, 2019 :
    Or it could that 5T paint chipping thing?
  6. Waveform Modifier Marshmallow Jul 16, 2019
    Muhsin_Sultan and B_Wrath like this.
  7. B_Wrath Marshmallow Jul 16, 2019
    This is not paint chipping. There are scuff marks where he claims the paint vanished into thin air.
    Muhsin_Sultan likes this.
  8. OnePlus OxygenOS Honeycomb Jul 17, 2019
  9. Yashvendra_Singh_Raghav Ice Cream Sandwich Jul 18, 2019
    Yashvendra_Singh_Raghav, Jul 18, 2019 :
    this is due to the cases we use on phones...
    they contain some chemicals in it... nd when you charge rhe device ... the device get slightly warm... nd chemical nd some dust particles that are normally there arround the phone body nd cover.... leaves the mark... nd spots....
    i dont have any answer for... spot on your devices...
    for this back panel will be changed...
    contact one plus support...
    charges would be available on one plus.in/spare parts
  10. Yashvendra_Singh_Raghav Ice Cream Sandwich Jul 18, 2019
  11. OnePlus OxygenOS Honeycomb Jul 19, 2019
    OnePlus OxygenOS, Jul 19, 2019 :
    that corrosion spot was probably some liquid could have seeped to the sides when dripped on phone surface....user probably only wiped the surface of screen but didn't open up case to off the remainder...
