Display Cracked and dead screen. How to unlock and backup?
  1. G_Kees_Quist_kmTb
    Cupcake Apr 22, 2017
    G_Kees_Quist_kmTb , Apr 22, 2017 :
    i dropped my OPO 3t at a gas station when on the way to smoky mountains national park for a few days of hiking. The crack was the only damage at first, then I lost use of the right side of the screen and a purple fringe started showing up.
    the purple spread and I slowly lost control of the rest of the screen.
    now im home and the service center says its standard procedure to wipe phones during repair which is terrible. I have tons of pictures I need to backup if I am to send it to them. I cannot access the storage from PC because I cannot unlock the phone using on screen pattern.
    Is there a way to enable usb debugging with adb, and then unlock the phone remotely using adb? I have no idea what else to do unless I want to try to replace the screen myself.... is it hard to do? UGH
  2. G_Kees_Quist_kmTb
    fdroko likes this.
  3. robdevil
    Gingerbread Apr 22, 2017
  4. G_Kees_Quist_kmTb
    yes, but the phone was off when I dropped it. the first unlock after booting must be with lock pattern, not fingerprint :(
  5. G_Kees_Quist_kmTb
    misspoke. I acutally used it to take pictures but it eventually died while hiking for a few days. after charging and booting at home, one must unlock with pattern before fingerprint works...
  6. robdevil
    robdevil , Apr 22, 2017 :
    Sorry but there is no other option than spare screen. Use cloud backup next time
    Z1521830057531 likes this.
  7. G_Andrew_Ashraf_gxLd
    Froyo Apr 22, 2017
  8. G_Kees_Quist_kmTb
    Best Answer
    lostLambda and cmitchellshaw like this.
  9. G_Andrew_Ashraf_gxLd
    Froyo Apr 22, 2017
    G_Andrew_Ashraf_gxLd , Apr 22, 2017 :
    smart!
  10. BadboyX17
    Cupcake Apr 23, 2017
  11. Vishal Batheja
    Cupcake Apr 28, 2017
    Vishal Batheja , Apr 28, 2017 :
    What's the solution then??And for how must you got your scren replaced??Please help.
  12. fdroko
    Jelly Bean Apr 29, 2017
  13. G_Farhan_Fahim_vUJb
    Froyo Apr 29, 2017
  14. lostLambda
    Lollipop Apr 29, 2017
  15. emili1001
    Cupcake Aug 19, 2017
    emili1001 , Aug 19, 2017 :
    Hi, I wonder if you could expand a bit on your explanation. I am not as tech savvy, but I have the same problem: broken screen going to purple and then going black, phone switches on, no debbug on, ...
    I am not familiar with the concepts and strategy you said you solved the problem. Would you/anyone be so kind to expand on that? thank you
    VicePresNotSure likes this.
  16. Sin.Horgan94
    Donut Feb 21, 2018
    Sin.Horgan94 , Feb 21, 2018 :
    Hi, would you maybe be able to expand on the solution you found please? I'm in the same situation now ( broken screen, no display, phone restarted, pattern unlock, debugging not enabled) and slowly running out of options. I know this is an old thread but I'd be forever grateful if you could reply. Thank you
  17. Mauricio Paez
    Cupcake Mar 21, 2018
    Mauricio Paez , Mar 21, 2018 :
    Can you explain better what you did please? I have the same problem and I didn't understand you. Many thanks!
  18. majefx
    Gingerbread Mar 21, 2018
  19. carlotta.jarach
    Cupcake Feb 15, 2020
