Other Curved Tempered Glass Screen Protector
  1. paulofaulo
    Honeycomb Dec 11, 2016
    paulofaulo , Dec 11, 2016 :
    Hey guys, do you know if the "Curved Tempered..." of the OnePlus3 fits with the Flip Cover?
  2. wenna
    Ice Cream Sandwich Dec 12, 2016
    paulofaulo likes this.
  3. paulofaulo
    Honeycomb Dec 12, 2016
    paulofaulo , Dec 12, 2016 :
    thank you and do you notice that there is less of the screen when you use ist normaly?
  4. wenna
    Best Answer
    wenna , Dec 12, 2016 :
    The fit is good but not perfect. A tiny little bit of screen gets covered on the very edges, but it's nothing I can't live with.
    Also a nice thing of the Amoled display is that the image seems almost like painted on top of the screen. With the glass protector the image sort of sinks into the display.
  5. paulofaulo
    ok thanks! But i think i´m gonna order the orzly because it doesn`t cover the screen at all.
  6. davidsaraiv
    Eclair Dec 12, 2016
    davidsaraiv , Dec 12, 2016 :
    So, if i got this right the screen protector steals some inches off the screen correct? Is there any way (with root or without it) to reduce the screen width to counter this?
  7. paulofaulo
    well, firstly yes, it is also a disclaimer at th eofficial oneplus store, so no secret. and i have no clue haha, but when you don´t want this at all (most people say it´s not such a big problem and you dont recognise it) then you can buy the orzly from amazon.
  8. davidsaraiv
    Eclair Dec 12, 2016
    But the orzly has many bad reviews...is the official from oneplus that bad? I bought the cheaper one from the oneplus but i regreted it since it does not cover the full screen (yes i know the description says that, but im new to the oneplus and i figured the official protector shouldnt had any issues...silly me)
  9. paulofaulo
    yeah, you have to think about whats more important to you. the Curved TGSP from oneplus is perfect exepct the thing with the edge, and the orzly got little less quality but you can see everything from the display. but the difference between the TGSP (cheaper) from oneplus and the curved TGSP from oneplus is clear, you can see it on the photos.
  10. Hrc4u
    Cupcake Dec 12, 2016
  11. paulofaulo
    Honeycomb Dec 13, 2016
    paulofaulo , Dec 13, 2016 :
    ok cool, report then please
  12. FbeShox
    Cupcake Jan 6, 2017
  13. Kopsukka
    Cupcake Jan 6, 2017
  14. jatingada
    Gingerbread Jan 7, 2017
    jatingada , Jan 7, 2017 :
    Don't buy, waste of money. Dosent sticks properly. cheap quality
  15. amaury986
    Cupcake Jan 20, 2017
    amaury986 , Jan 20, 2017 :
    Do you know if is it possible to obtain a refund? It's horrible to see this screen protector
  16. jatingada
    Gingerbread Jan 20, 2017
    jatingada , Jan 20, 2017 :
    wish even I could get the refund. Oneplus please refund the money back. Such cheap qualities tempered glass and highly priced. Wasted my Rs.1500/-.
  17. Manish.Bhardwaj
    Cupcake Feb 1, 2017
    Manish.Bhardwaj , Feb 1, 2017 :
    I was considering buying the curved tempered glass for op3t from the official store. what issues did you face? what other brand do you suggest?
  18. Gajender Patel
    Cupcake Feb 1, 2017
  19. K_rajnish
    Donut Feb 1, 2017
  20. Onkar.Singh
    KitKat Feb 1, 2017
    Onkar.Singh , Feb 1, 2017 :
    There are a lot of user reviews stating rainbow reflection/coloring on the screen with curved TGSP .... Some also report that the dot matrix grid is very visible and hence not a perfect option ...
