Custom Notification sound
  1. F_Alex_Kolpakov_cqPz
    Donut Jul 19, 2017
    F_Alex_Kolpakov_cqPz , Jul 19, 2017 :
    How can I set a custom notification sound without rooting?
    I put a sound in the notification folder but it won't show in the settings...
    Thank you
  2. jack_frost
    Honeycomb Jul 19, 2017
    jack_frost , Jul 19, 2017 :
    If its in ogg/mp3 format it will show.
    Choose the first option "Local ringtone" and it will populate all your local sounds from the notifications/ringtones directory
  3. ut2000
    Honeycomb Jul 20, 2017
    ut2000 , Jul 20, 2017 :
    you need to use a third party. dumbass OnePlus doesn't let you for some reason.
  4. Headshots4life
    Gingerbread Jul 20, 2017
    Headshots4life , Jul 20, 2017 :
    You don't need to use a third party. You just download whatever ringtone/notification you want and just select local ringtone and select it and you're done. Easy.
  5. ut2000
    No. It doesn't work for custom notification.
  6. Headshots4life
    Ah. You are correct. My mistake. Lol. Only sms and ringtone can have custom tones. Not a big deal to me to be honest. As long as I can customize my sms and ringtone I'm happy.
  7. F_Alex_Kolpakov_cqPz
    Donut Jul 20, 2017
  8. F_Leonardo_Storti_vzHk
    Eclair Jul 20, 2017
    F_Leonardo_Storti_vzHk , Jul 20, 2017 :
    I use this app called Zedge, download it it is pretty useful I use custom notifications very easy to use, although it does have ads but trust me it works...
  9. Rodriguezz
  10. aasif777
    Cupcake Jul 21, 2017
  11. jaspinder singh
  12. JohnTylerHearn
    Cupcake Aug 2, 2017
    JohnTylerHearn , Aug 2, 2017 :
    I use "Ringtone Maker" by publisher Big Bang Inc. Use the option "set as default notification for the sound file you want. I wanted to make Bastion's chirping sounds my text tone and this app let me do it with no hassle. 10/10
  13. VaibhavBhargava
    Lollipop Aug 2, 2017
    VaibhavBhargava , Aug 2, 2017 :
    Create a folder in root called Notifications and store your favourite custom notification sound in .ogg/mp3 format. (preferably in .ogg)
