2
[Answered] Custome ringtone issue After 8.1 upgrade 5.1.0 on one plus 5T
  1. pressanna
    Froyo Apr 24, 2018
    pressanna , Apr 24, 2018 :
    After using alert slider, custom ringtone is not working, no phone ringing only vibrates.
    Cleared the cache and rebooted the phone, it worked for a while and now without using the slider it happens again.
    Each time phone needs to be rebooted to ring the custom ringtone. Default ringtone has no issues.
    grk007 and wwegleitner like this.
  2. wwegleitner
    Gingerbread Apr 24, 2018
    wwegleitner , Apr 24, 2018 :
    I have the Same issue.
    Is Started Witz a Beta Version anderen was eventually solved. Bitte returned now in the stable and in the Beta Version. VERY ABNOYING
    pressanna likes this.
  3. grk007
    Honeycomb Apr 25, 2018
    grk007 , Apr 25, 2018 :
    Was this a problem in previous software versions - It was there in previous version OOS 5.0.3 and there was a fix in OOS 5.0.4.
  4. pressanna
    Froyo Apr 25, 2018
    pressanna , Apr 25, 2018 :
    yes and now the same issue with 8.1 (5.1.0)
