6
CYANHACKER v3 Custom ROM ( Lollipop Based)
  1. rustagi
    Ice Cream Sandwich Feb 3, 2015
    rustagi , Feb 3, 2015 :
    Hi Guys,
    I have installed CYANHACKER v3 ROm on my Oneplus Today.
    To start its an ALPHA staged ROM.
    You cant record Video in 4K but 1080p is enabled.
    Till now no other bug found.
    Battery consumption would be updated after a weeks use.
    Screenshots are attached below: Screenshot_2015-02-03-13-27-46.png Screenshot_2015-02-03-13-45-57.png Screenshot_2015-02-03-14-47-17.png Screenshot_2015-02-03-15-16-59.png Screenshot_2015-02-03-15-17-05.png Screenshot_2015-02-03-15-17-11.png Screenshot_2015-02-03-15-35-05.png Screenshot_2015-02-03-15-38-14.png
  2. Armsheezy
    Jelly Bean Feb 3, 2015
    Armsheezy , Feb 3, 2015 :
    The base of these Roms are CM12 only. I may be wrong. @vigneshvar1
  3. Vicky_cbe
    KitKat Feb 3, 2015
    niroocool and Dhrumin226 like this.
  4. rustagi
    Yup the base is CM12 but I couldnt flash CM12 so flashed it.
    It will get more features then CM12 in the future.
    Dhrumin226 likes this.
  5. Vicky_cbe
    KitKat Feb 3, 2015
    Vicky_cbe , Feb 3, 2015 :
    yes true :) more features will come soon but stability wise i doubt it
    saiki4116 and Dhrumin226 like this.
  6. rustagi
    Yup its in alpha stage right now...
    Just wanted a lollipop based rom and this one made me interested so installed it.
    Would update soon about its stability.
    Dhrumin226 and vigneshvar1 like this.
  7. Vicky_cbe
    KitKat Feb 3, 2015
    sure bro :)
  8. Armsheezy
    Better install Cm12. Its the best as of now.
    arifathar likes this.
  9. rustagi
    tried it also....tried installing nightly of 3 feb 2015 but it cudnt be installed so didnt know what to do.
    hence installed this
  10. Armsheezy
    What was the issue. Ill help you.
  11. rustagi
    I tried to flash it but twrp kept on reopening...
  12. Armsheezy
  13. Vicky_cbe
    KitKat Feb 3, 2015
    if you could get into twrp and install this then there was no problem with twrp. must be some other problem from your download because today i did a fresh install cm12 with the latest build.
    everything including ambient display is working well for me
  14. rustagi
    Now I installed yesterdays nightly....it flashed easily...ambient display though is a problem...rest all is good...
  15. mayanks
    mayanks , Feb 3, 2015 :
    also see if your twrp is updated to the final version. previous versions had some problem with screen crashing.
  16. rustagi
    Ice Cream Sandwich Feb 4, 2015
    rustagi , Feb 4, 2015 :
    Ins
    talled 2 feb nightly and installed cyandelta...but still theres a problem in installing the delta file for 3 feb
  17. mayanks
    Jelly Bean Feb 4, 2015
    mayanks , Feb 4, 2015 :
    is ur twrp updated to 2.8.4.1?
  18. rustagi
    yes it is 2.8.4.1
  19. rustagi
    when using Cyandelta to update to todays nightly; the following error comes[​IMG]
  20. sid994
    sid994 , Feb 4, 2015 :
    No prob its just because u haven't enabled root access just do this settings<about phone<tap 8 times on build no. to enable developer options....Now go to developer options & in that go to root..& change it to apps & adb...this will enable root access & now you will face no problem in installation through cyandelta
