Cyanogen OS 12 BOOTLOOP!
  1. kill3r_tadej
    Froyo Apr 28, 2015
    kill3r_tadej , Apr 28, 2015 :
    2 Days ago I manually install Cyanogen OS 12! Now i was reboot it and Im stuck in bootloop. I mean im stuck when its loading some widgets and i can see screen for sec and then loop again in boot picture! Now problem is that i don't know how to turn phone off and phone is not unlocked! What to do?
  2. bombadier
    KitKat Apr 28, 2015
  3. amartens181
    KitKat Apr 28, 2015
  4. kill3r_tadej
    Froyo Apr 28, 2015
  5. Baymax
    Starting Point Expert Community Expert Apr 28, 2015
    Baymax , Apr 28, 2015 :
    Ouch bruh. You might have to wipe it. My recommendation is wipe it, root it, TWRP it and that way you can backup without worry
  6. kill3r_tadej
    Froyo Apr 28, 2015
  7. Formsma
    KitKat Apr 28, 2015
    Formsma , Apr 28, 2015 :
    Well, that is what a full wipe does right? Always make backups before manually install stuff. Meh, always make backups, not only when installing stuff.
  8. return.of.octobot
    Jelly Bean Apr 28, 2015
    return.of.octobot , Apr 28, 2015 :
    Ayyy another one..
    What exactly were you attemting to do before this happened.
    You can turn the phone off by holding the power button down for ~10 secs, or pulling the battery, there's always that.
  9. ceccorubik
    Honeycomb Apr 28, 2015
  10. umberto75
    Gingerbread Apr 28, 2015
    umberto75 , Apr 28, 2015 :
    I think you have to push and keep holding the power button for minimum 20 seconds. You will see that if the battery is completely out of charge, this will keep by it self the force to switch on the phone. Dont worry about it . After that, you would do to charge trhough usb computer's port!
  11. kill3r_tadej
    Froyo Apr 28, 2015
    Did that but wasn't work soo i did full wipe cache and it worked :D and lose stuff :D
