65
Cyanogen OS 12, Rolling Out Now
  1. ScorpioPirate
    Ice Cream Sandwich Jun 1, 2015
    ScorpioPirate , Jun 1, 2015 :
    NO.... But I can try to look into my "Magic Ball".... :)
    NWKENT likes this.
  2. lahiruplanet
    Froyo Jun 2, 2015
  3. ScorpioPirate
    Ice Cream Sandwich Jun 2, 2015
    ScorpioPirate , Jun 2, 2015 :
    I think that you have a' bad downlod that get wrong.
    Try to download again.... But follow this steps and download links >
    https://forums.oneplus.net/threads/guide-ota-manual-install-easy.297425/
    1. Using your OnePlus One, download the OTA file straight from Cyanogen.http://builds.cyngn.com/cyanogen-os...816218e8a/cm-12.0-YNG1TAS17L-bacon-signed.zip
    2. Reboot into Recover
    3. Select Apply Update
    4. Locate the downloaded file - Where you saved it (generally Downloads)
    5. Tapping the file will initialize the install!
    6. Reboot when that Recovery option reappears, it happens quickly!
    7. All done! Just wait for phone to do its job. 5 minutes or more
  4. lahiruplanet
    Froyo Jun 2, 2015
    lahiruplanet , Jun 2, 2015 :
    thank for your given steps :)
    what is cm-12.0-YNG1TAS17L-bacon-signed-fastboot.zip?
    Reference: https://cyngn.com/support
  5. ScorpioPirate
    Signed fastboot zip: This contain the complete rom and can overwrite everything including your data partition. These cannot be flashed via recovery - extract their contents and flash via fastboot.
    So DON'T use this in your update :)
    You have to use:
    Signed zip: Normal recovery-flashable zip that contains just the system and kernel (they won't overwrite your data partition)
    lahiruplanet likes this.
  6. lahiruplanet
    Froyo Jun 2, 2015
    thank you very much for your informations :)
    ScorpioPirate likes this.
  7. Hals
    Cupcake Jun 3, 2015
  8. windshear
    Ice Cream Sandwich Jun 3, 2015
    braud likes this.
  9. ScorpioPirate
    Ice Cream Sandwich Jun 4, 2015
    ScorpioPirate , Jun 4, 2015 :
    They still fix bugs from CM12 to CM12.1..... still 109 bugs to go :)
    So just be patience and stay cool and wait :)
  10. chriskao
    Cupcake Jun 5, 2015
    chriskao , Jun 5, 2015 :
    How can One Plus manage to screw up something so essential such as the touch screen. It has rendered my phone unusable. Bunch of amateurs.
  11. MatthUnderpants
    Gingerbread Jun 5, 2015
    MatthUnderpants , Jun 5, 2015 :
    Why are you so excited installing CM12S? Lollipop at the moment is so buggy with a lot of apps... I'll wait 5-6 months before updating.
  12. A26
    Donut Jun 6, 2015
  13. oneplusone2024
    Eclair Jun 6, 2015
    oneplusone2024 , Jun 6, 2015 :
    I have a new phone coming do you recommened staying on 11s for now till the bugs are ironed out and 12s is stable? How do I stop from getting the OTA when I finally setup my phone?
  14. peos
    Ice Cream Sandwich Jun 6, 2015
    peos , Jun 6, 2015 :
    I can't tell you what to do, i'm still on 44S without any problems, so for me there is no need to update right now. To deactivate the OTA message you xan simply go to: preferences->apps->all->system updates (com.cyngn.fota) and deactivate it ;)
    Greetz peos
    oneplusone2024 and joecastellon like this.
  15. MatthUnderpants
    Gingerbread Jun 6, 2015
    MatthUnderpants , Jun 6, 2015 :
    Oh yeah man! Lollipop by my mind is not ready for dayly use.
    joecastellon likes this.
  16. JoeyTeckno
    JoeyTeckno , Jun 6, 2015 :
    This.
    Thank you for this.
    EDIT: hmmm, the "Disable" button and "Show notifications" checkboxes are grayed out. I am not able to disable this app, and can't uncheck to disable notifications :(
  17. peos
    Hmm that's not normal, I would say. Which build are you on? For me it looks like this:
  18. sh.pianist
    Froyo Jun 6, 2015
    sh.pianist , Jun 6, 2015 :
    In the meantime I've installed the update and I am very pleased with it. :) turned off wake feature (OK oneplus) and all gestures and play services from cm11s already restricted. Works very Nice and fast. I also noticed my battery drain from using GPS is slightly less.
  19. xephael
    Cupcake Jun 6, 2015
    xephael , Jun 6, 2015 :
    I just got my phone yesterday and it has only updated to 11.0-XNPH05Q.
    Without reading through 80 pages, did Oneplus One ditch all the CyanogenMod users and this update...basically making it a PITA for users to get 12S on their devices?
  20. oneplusone2024
    Eclair Jun 7, 2015
    oneplusone2024 , Jun 7, 2015 :
