35
Cyanogen OS 13 - First impressions
  1. dhirajuchil007
    Eclair Apr 10, 2016
    vanj44 likes this.
  2. ishtiyaaq50
    Honeycomb Apr 10, 2016
    ishtiyaaq50 , Apr 10, 2016 :
    What player are you using ?It works fine for me with phonograph.
  3. CasperTFG
    KitKat Apr 10, 2016
    CasperTFG , Apr 10, 2016 :
    Recheck your APN settings?
  4. dhirajuchil007
    Eclair Apr 10, 2016
    dhirajuchil007 , Apr 10, 2016 :
    I use Saavn .it used to work with saavn in cos12.1....
  5. CasperTFG
    KitKat Apr 10, 2016
    Yea, not impressed with ColorOS camera port. Seems pictures aren't as clear.
    felix_g0 likes this.
  6. CasperTFG
    KitKat Apr 10, 2016
    And don't forget kiddos, in case COS 13 borks your T-Mobile APN settings, here they are again:
    Name: T-Mobile US LTE
    APN: fast.t-mobile.com
    Proxy: Not set
    Port: Not set
    Username: Not set
    Password: Not set
    Server: Not set
    MMSC: http://mms.msg.eng-t-mobile.com/mms/wapenc
    MMS Proxy: Not set
    MMS Port: Not set
    MCC: 310
    MNC: 260
    Authentication type: Not set
    APN type: default,supl,mms,hipri,dun
    APN protocol: IPv4/IPv6
    APN roaming protocol: IPv4
    APN enable/disable: APN enabled
    Bearer: Unspecified
    MVNO: None
    MVNO: Not set
    ktklein72 likes this.
  7. ahighfield
    KitKat Apr 10, 2016
    ahighfield , Apr 10, 2016 :
    Here is mine...I have been longing to see this sort of profile, flat areas and white space in the "awake" row...Perhaps try rebooting and then a factory reset, sometimes the update takes a few cycles/days to "settle in", particularly for battery optimisation. It looks like I should now be getting comfortably through a full day again, memories of 44S!
  8. Dweezy91
    Gingerbread Apr 10, 2016
    Dweezy91 , Apr 10, 2016 :
    Yep my APN is correct, ever since the update they took out the "LTE" on quick setting I'm just stuck on "H" or "H+"
  9. lder
    lder , Apr 10, 2016 :
    Happened to me once.
    Music visualizer working fine with google music player
  10. lder
    Not able to enter Battery Settings! Every time i try to enter Settings crash, i get a screen notification of what happened and i'm back again on the homescreen or app tray. Anyone else?
    Really trying not doing a factory reset since most of it seems stable enough.
  11. Zouille
    Donut Apr 10, 2016
    Zouille , Apr 10, 2016 :
    Hello
    I Update my OPO and it was fine but impossible to enter in the " battery settings", I have a popup :" settings close "
    What can I do ?
  12. hAiwahn
    Eclair Apr 10, 2016
  13. lder
    Same here. Did a wipe cache in recovery and also cleaned up my cached files in Settings. Well if nobody found a way to solve this i'll probably do a factory reset
  14. ZioArturone
    Froyo Apr 10, 2016
    Dweezy91 likes this.
  15. Tricksodave
    Jelly Bean Apr 10, 2016
    Tricksodave , Apr 10, 2016 :
    Anyone know what this demo mode is? You get it by clicking on the build date.
    Also having trouble getting the clock widget to display the weather. Location is enabled.
  16. imTSS
    KitKat Apr 10, 2016
    imTSS , Apr 10, 2016 :
    Yahoo weather source is having issues. Select the other one
    Tricksodave likes this.
  17. Tricksodave
    Cheer's, that was doing me in haha
    imTSS likes this.
  18. lder
    :mad: I knew something i used all the time was missing!
  19. pranavsultania
    Froyo Apr 10, 2016
    pranavsultania , Apr 10, 2016 :
    I feel the touchscreen is not very responsive. Everything else seems okay.. Anybody knows a fix for that?
  20. LEQIUX
    Ice Cream Sandwich Apr 10, 2016
