43
ROM CyanogenMod 6.0.1 Builds
  1. mymutatedmind
    Ice Cream Sandwich Feb 22, 2016
    mymutatedmind , Feb 22, 2016 :
    ... Only one thing remains for this ROM for perfection... Sultans camera hal.. :)
    69gm likes this.
  2. jgcaap
    jgcaap , Feb 22, 2016 :
    building a version with 3.4.0 kernel tomorow. Like that you have the coolness of both worlds.
    galaali, 69gm, bmark240 and 2 others like this.
  3. bmark240
    bmark240 , Feb 22, 2016 :
    Excellent stuff Jorge. Now we will have one of the best CAF based ROM as well :p ;)
  4. Evokkimus
    KitKat Feb 23, 2016
    Evokkimus , Feb 23, 2016 :
    Hey @jgcaap will you still be supporting f2fs on cache and data? I'm kind of scared to try out some roms with my cache and data on f2fs, as trying out Darkobas actually wiped my internal storage because of it.
  5. bmark240
    Ice Cream Sandwich Feb 23, 2016
    bmark240 , Feb 23, 2016 :
    @Evokkimus: The ROM is optimized for f2fs...If your Cache & Data are already on f2fs -check it by running TWRP it will stay on f2fs.
    Evokkimus likes this.
  6. Evokkimus
    KitKat Feb 23, 2016
    Yea I'm on f2fs cache and data, been so for some time now. Currently formatting system back to ext4 and moving to Jgcaap's rom.
  7. bmark240
    Hmm. I'm having a few errors with OTG file transfer. It hasn't seemed to work properly since after the Feb 18 version using Es File Explorer or other file explorers like Solid Explorer & Root Explorer....
    Edit: reflashed the newest build and errors are not as frequent.
  8. Setting.out
    Gingerbread Feb 24, 2016
    Setting.out , Feb 24, 2016 :
    Try reverting kernel versions (3.69 should work) to what the 18th was using, or flash the boot.img from the 18th and see if otg returns...
  9. Aaahh
    Marshmallow Feb 24, 2016
    Aaahh , Feb 24, 2016 :
    I have to ask, where are you getting these patches. I see the cm ones, but like especially the kernel, where are they coming from.
    Also are you pushing?
  10. 69gm
    Jelly Bean Feb 24, 2016
    69gm , Feb 24, 2016 :
    Is this your 2-23 build?
  11. jgcaap
    Ice Cream Sandwich Feb 24, 2016
    jgcaap , Feb 24, 2016 :
    No. Didn't had time. I'll try on weekend.
    69gm likes this.
  12. arvindautar
    Eclair Feb 24, 2016
    arvindautar , Feb 24, 2016 :
    Try find7op camera blobs ( slimsaber e.g ) with colorOS cam 50 mp plugin. Best overall. Oxygenos cam libs as used in nuclear rom or aosparadox ( not sultan because his HAL breaks things ) produce good pictures too, not entirely sure if even better than the find7op cam blobs....it seems so at first glance though - needs more testing.
    sultan hal is nice for video recording
  13. arvindautar
    Eclair Feb 24, 2016
    exciting times for you now that you joined exodus team! Will you be doing next to the optimisations other things too? :)
  14. bmark240
    bmark240 , Feb 24, 2016 :
    @arvindautar : yes, jgcaap is adding features from exodus builds. He also has been adding improvements like f2fs compression compatibility as well as lz4 builds. He also likes to improve Java and art/bionic frameworks too.
  15. arvindautar
    Eclair Feb 24, 2016
    Hi, i meant for(not from) the exodus rom :)
  16. 69gm
    Thanks!!!
  17. Evokkimus
    KitKat Feb 24, 2016
    Evokkimus , Feb 24, 2016 :
    As long as CG won't come to this rom I will be using this ;)
    Valokuvaaja likes this.
  18. jgcaap
    Ice Cream Sandwich Feb 25, 2016
    jgcaap , Feb 25, 2016 :
    Didn't push yet. I'll make my contribution to the community after I finish :)
  19. jgcaap
    I won't add stuff from exodus.. I'll add my own to exodus :p please do not make a confusion on that! Hehe
    Jole7, Valokuvaaja and Evokkimus like this.
  20. 69gm
    Jelly Bean Feb 25, 2016
    69gm , Feb 25, 2016 :
