43
ROM CyanogenMod 6.0.1 Builds
  1. digitalpig
    Donut Jun 23, 2016
    digitalpig , Jun 23, 2016 :
    The gapps link he provided at xda is correct. He links to the slim gapps and it's up to you to decide whether you will go with the mini or the zero version of it. If you're using now on tap, chose mini.
    As for the recovery, I still use TWRP 2.8.6.0 and never ran into issues. I see no reason to upgrade, don't fix it if it ain't broken, you know. ;)
    se7enlyn likes this.
  2. Rahuvich
    Honeycomb Jun 23, 2016
    Rahuvich , Jun 23, 2016 :
    Well I updated the TWRP bc the lastest version was the recommended in another ROM
  3. Zacharybinx34
    Donut Jul 11, 2016
    Zacharybinx34 , Jul 11, 2016 :
    So a couple of months back I was using Sultan's rom and I had great signal at work - 4G and everything. However, in the past month on this build, and this one I can only get 3G that bounces back and forth between 3g and HSPA+. I've tried the CM modem and the Oxygen one. Anything else i can do to fix this?
    Thanks!
  4. Max.Mar
    Jelly Bean Jul 15, 2016
  5. sfomin
    Nougat Jul 15, 2016
    sfomin , Jul 15, 2016 :
    ditching Marsh i see[​IMG]
    jstepa likes this.
  6. Max.Mar
    Max.Mar , Jul 15, 2016 :
    Nahh..not actually. But this ROM seems promising and would like to try it out. I like to test different ROMs..wanted to know what this ROM has to offer.
    sfomin likes this.
  7. Max.Mar
    But no matter what.."touchwiz is king".. Bullshittt :D
    sfomin likes this.
  8. sfomin
    Nougat Jul 15, 2016
    indeed. TouchWiz is King[​IMG]
    Gonzo01 and Max.Mar like this.
  9. Max.Mar
    Cm'on man...dats cheating. You can't do that.
    sfomin likes this.
  10. ziepicwaffle
    Ice Cream Sandwich Jul 15, 2016
    ziepicwaffle , Jul 15, 2016 :
    If you check XDA you can see the progress. This ROM is very active, with builds pushed out nearly everyday.
    se7enlyn and Max.Mar like this.
  11. Max.Mar
    Is it OTA ready?
    EDIT: also do let me know the best way to update this ROM time to time without clean flash. And also I can't download Full ROM zip everytime..so is there any quick way to do that.
  12. ziepicwaffle
    Unfortunately there is no ota. You can dirty flash from build to build but you have to download the whole ROM zip...
  13. se7enlyn
    Ice Cream Sandwich Jul 16, 2016
    se7enlyn , Jul 16, 2016 :
    you don't need to flash each and every update. i'm on 0704 and its rock solid. even if there are new builds, i don't need to flash them as there's absolutely nothing wrong with 0704.
    ziepicwaffle likes this.
  14. Deactivated User
    Jul 17, 2016
  15. ziepicwaffle
    Ice Cream Sandwich Jul 17, 2016
    ziepicwaffle , Jul 17, 2016 :
    No need to change the format of anything, just clean flash this ROM with Gapps. I forget if you need supersu though.
  16. Deactivated User
    Jul 17, 2016
  17. ziepicwaffle
    If you're on the XDA thread, the build that's in the title is the one that the developer considers stable.
    Deactivated User likes this.
  18. Deactivated User
    Jul 17, 2016
  19. Max.Mar
    Jelly Bean Jul 18, 2016
    Max.Mar , Jul 18, 2016 :
    Cud u plz tell me which one it is..as I don't have access to the XDA (Office restrictions :oops:)
  20. ziepicwaffle
    Ice Cream Sandwich Jul 18, 2016
    ziepicwaffle , Jul 18, 2016 :
    7/10 build
    Max.Mar likes this.
