43
ROM CyanogenMod 6.0.1 Builds
  1. ziepicwaffle
    Ice Cream Sandwich Aug 4, 2016
    ziepicwaffle , Aug 4, 2016 :
    Probably the system profiles:p
    se7enlyn likes this.
  2. se7enlyn
    se7enlyn , Aug 4, 2016 :
    yup
    i like system profiles too but the cm drain is really unbearable. bought tasker but realised i can't use the 2G/3G switch.:(
    ziepicwaffle likes this.
  3. rkiwtir
    rkiwtir , Aug 4, 2016 :
    Yes,System profiles , cm themes n privacy guard! Guess, i can switch for aosp for now , until I find a good cm ROM ,with good battery life . and what's difference between darkobas n Candy six?
    ziepicwaffle and se7enlyn like this.
  4. se7enlyn
    candysix dev is more active than darkobas. darkobas' dev bought a 6P so not much emphasis on OPO.
    darkobas has less features/customisations.
    go on youtube, search for ' game of roms ' and you will find video reviews of these 2 roms.
    ziepicwaffle, jstepa and rkiwtir like this.
  5. rkiwtir
    Looks cool , it has cm theme so ,I'll flash that. And can I flash some other gapps , i don't want bloat my phone with unnecessary gapps ,i usually use nano or pico
  6. jstepa
    KitKat Aug 4, 2016
    jstepa , Aug 4, 2016 :
    I agree with you mosty about the Devs activity, but Darkobas still gets updated quite regulary, only from OTA though...
  7. ziepicwaffle
    You can use Banks. It's a big file but it only actually installs a very minimal amount of stuff. It's just large because it works on all devices so you don't have to worry about installing the wrong package. Never had any problems with it, I know there are some banks gapps fans in this forum ;)
    se7enlyn and jstepa like this.
  8. ziepicwaffle
    Candy has privacy guard if that's important to you. Darkobas has less features but it's battery to me is the best. Candy is close. Darkobas uses color os blobs vs candy which uses sultans camera(that's your preference). Both are very good.
    se7enlyn and daniga74 like this.
  9. jstepa
    KitKat Aug 4, 2016
    One here, with Banks every ROM works and no problems :)
    se7enlyn and ziepicwaffle like this.
  10. daniga74
    Jelly Bean Aug 4, 2016
    daniga74 , Aug 4, 2016 :
    I like system profile too
  11. Max.Mar
    Jelly Bean Aug 12, 2016
    Max.Mar , Aug 12, 2016 :
    Is there any possibility to incorporate the OP3 Dash charge feature (Like- to keep phone cool while charging, mine gets really hot and lil bit fast charging too if possible) into this ROM for our OPO.
  12. daniga74
    Jelly Bean Aug 26, 2016
  13. Setting.out
    Gingerbread Aug 26, 2016
    ziepicwaffle and daniga74 like this.
  14. Setting.out
    Gingerbread Oct 15, 2016
  15. jstepa
    KitKat Oct 15, 2016
  16. Setting.out
  17. jstepa
    KitKat Oct 15, 2016
    jstepa , Oct 15, 2016 :
    Just make an U-turn...
  18. Gonzo01
    Lollipop Oct 15, 2016
    Gonzo01 , Oct 15, 2016 :
    good to see you alive and kicking :D
  19. jstepa
    KitKat Oct 15, 2016
    Kicking yes, alive not so sure anymore ;):p
    se7enlyn and Gonzo01 like this.
  20. Gonzo01
    flash then... a good deep clean flash :p
