5
CyanogenOS 13.1.1-ZNH2KAS2X1-bacon Patch - 04/08/2016
  1. mitssadii
    Cupcake Aug 16, 2016
    mitssadii , Aug 16, 2016 :
    I installed the CyanogenOS 13.1.1-ZNH2KAS2X1-bacon Patch ,the phone is not detecting the SIM
  2. Deactivated User
    Aug 16, 2016
  3. kpoyser
    Gingerbread Aug 17, 2016
    armmani2001 likes this.
  4. armmani2001
    KitKat Aug 17, 2016
  5. HacKaos
    Cupcake Aug 17, 2016
  6. armmani2001
    KitKat Aug 17, 2016
    armmani2001 , Aug 17, 2016 :
    I installed Accuweather, it's even better and shows weather always on top
  7. armmani2001
    KitKat Aug 17, 2016
    What! i have to try now...
    Mine works..
    billy88 likes this.
  8. dashingfahad11
    dashingfahad11 , Aug 17, 2016 :
    Problem with dailer. Annoying software updates. Saved contacts not showing on dialer when typing half the number. Like if I type 9 in dialer it used to show the numbers starting with 9 and the contacts which has 9 or the words with 9 in keypad.
  9. go8soccer
    Ice Cream Sandwich Aug 17, 2016
    go8soccer , Aug 17, 2016 :
    As if the "occasional random reboots" aren't enough to fix ASAP... I don't understand cyanogen sometimes :confused:
  10. armmani2001
    KitKat Aug 17, 2016
    Well, we have lowered our expectations with Cyanogen :oops:
    TForesto likes this.
  11. go8soccer
  12. TForesto
    Gingerbread Aug 19, 2016
  13. Mandraker
    Froyo Aug 19, 2016
    Mandraker , Aug 19, 2016 :
    Hyperlapse mode not showing in camera (anybody else got this too?) is the only "problem" so far. Other then that I didn't come a cross any issues. Battery life did not improve but didn't get worse either, looks like overall it's running smoother.
    Uninstalled some of the Microsoft mods that I don't use, or will be using. And I wiped cache in recovery right after update. I alway's do that for some reason.
  14. Oakmario
    Donut Aug 19, 2016
    Oakmario , Aug 19, 2016 :
    For those of you that have wiped the cache in recovery after the update, do you still have the weather provider in the cLock widget? My OnePlus One is still pure stock and I have never rooted or done any customizations to it and yet the cLock widget no longer has a weather provider option after this update.
  15. Deactivated User
    Aug 19, 2016
  16. johncel.espares
    Froyo Aug 19, 2016
  17. drmahantesh
    Froyo Aug 20, 2016
  18. Mandraker
    Froyo Aug 20, 2016
    Mandraker , Aug 20, 2016 :
    Weather is gone for some reason.
  19. gringoboy
    Lollipop Aug 20, 2016
    gringoboy , Aug 20, 2016 :
    You have to install a weather provider now, I think Yahoo stopped providing it. Seen many using Chronus, but I use BBC coz I'm in UK and it seems better for here.
  20. Costi Redux
    Cupcake Aug 20, 2016
    Costi Redux , Aug 20, 2016 :
    Question: I have already installed OTA the ZNH2KAS2X1-bacon Patch but I have some stability issues with the 4G network. Can I install on top of it the full ZNH2KAS2X1 771mb version from local storage through OS recovery or I have to do it only through ADB? I'm on stock, no root. Thanks
