5
CyanogenOS 13.1.1-ZNH2KAS2X1-bacon Patch - 04/08/2016
  1. rwmchan
    Jelly Bean Aug 10, 2016
  2. VirtuosoLoki
    Gingerbread Aug 10, 2016
    VirtuosoLoki , Aug 10, 2016 :
    Weather widget no longer compatible with this version of cos. Nothing wrong with ur phone or the OS.
  3. dashingfahad11
    dashingfahad11 , Aug 10, 2016 :
    Screenshot pictures on stock gallery is not clear unless it's zoomed. This bug is present from a long time. But on other gallery they seemed to look clear.
  4. DopeDeadpool
    Froyo Aug 10, 2016
    DopeDeadpool , Aug 10, 2016 :
    guys my phone is not showing missed call notifications since the update ......any fix???
    ps: nevermind it fixed after a reboot:)
    rwmchan likes this.
  5. DopeDeadpool
    Froyo Aug 10, 2016
    does anyone knows how to get back weather widget in notification shade......after this update i cannot find any method to get it back...
  6. smrtphn
    Ice Cream Sandwich Aug 10, 2016
  7. ericthebeige
    Froyo Aug 10, 2016
    ericthebeige , Aug 10, 2016 :
    I get the same thing, totally random maybe once a week.
  8. lechevalierr
    Donut Aug 10, 2016
    waldwolf likes this.
  9. waldwolf
    waldwolf , Aug 10, 2016 :
    Just prior to seeing/reading your above post, I updated my OPO with the OTA CM13.1.1ZNH2KAS2X1-Bacon patch, so could not run your test on the earlier edition of CM13.0.1, however, tried your suggested test and my camera works fine. No hang. Did the test 5 more times and no problems seen.
    My OPO is almost 2 years old. Have never modified or installed any other camera software or app. I don't have a answer to the problem, but hopefully OP or CM will eventually come up with a solution. Good luck.
  10. rwmchan
    rwmchan , Aug 10, 2016 :
    weather widget setting removed. it's better to install other weather app, e.g. weather channel, etc.
  11. rwmchan
    i think that cyanogen has intentionally removed weather widget including the weather info on the notification. better to install another weather app.
  12. rwmchan
    maybe u can try to install gps status & toolbox
  13. Kinky
    Honeycomb Aug 10, 2016
    Kinky , Aug 10, 2016 :
    FYI (in case it's relevant to anyone), just got my OTA update now and is currently installing. 100% stock phone.
  14. DopeDeadpool
    Froyo Aug 10, 2016
  15. World_peace_91
    Eclair Aug 10, 2016
    World_peace_91 , Aug 10, 2016 :
    Unfortunately I always get the message that my /system or /vendor partition has been modified and when I ignore it, the update crashes and doesn't install.
    Any solutions?
    EDIT:
    Ha, I made it.
    I just let FlashFire flash the older complete Update.zip and put the incremental in second place.
    It worked just fine. Only had to flash Xposed again and everything was working again
    okak24 likes this.
  16. jameelsami13
    Cupcake Aug 10, 2016
    jameelsami13 , Aug 10, 2016 :
    I think i read it on twitter that one plus is working on an update to provide LTE for opo users in india . Is this true or a rumour
  17. bero74
    Eclair Aug 10, 2016
    bero74 , Aug 10, 2016 :
    Bluetooth connection with cars is a hell with COS 13. Random reboots/hang when making calls.
    Airbag888 and World_peace_91 like this.
  18. daniga74
    daniga74 , Aug 10, 2016 :
    to install the ota:
    1. Download the Factory Image for your current version of android
    2. Extract from it: boot.img, recovery.img, and system.img)
    3. Move these files to your ADB directory
    4. make sure your device is connected with working drivers and is in bootloader mode ( adb reboot bootloader )
    5. type the following commands:
    6. fastboot flash boot boot.img
    7. fastboot flash recovery recovery.img
    8. fastboot flash system system.img
    9. fastboot reboot
    10. apply the OTA
  19. daniga74
    maybe you need to install a weather provider.
  20. daniga74
    try to reset network configuration in backup and restore
