Dark mode and Android auto via OnePlus 8 T-Mobile
  1. H1542153384332
    Gingerbread May 8, 2020
    H1542153384332 , via OnePlus 8 T-Mobile , May 8, 2020 :
    Android auto is built into the 8 series with Android 10, and if using dark mode on my OP8 night mode is always on Android auto car screen. If I turn off dark mode on phone Android auto will stay bright both night and day. Anyone else have this problem?
  2. R4nger
    Froyo May 8, 2020
    R4nger , via OnePlus 8 Pro , May 8, 2020 :
    yes I do as well.
    I have a pioneer head unit connected via USB.
    iirc there is a setting to change it automatically or manually on my headset.
    would be nice if it was automatic.
  3. #3
    H1542153384332 and R4nger like this.
  4. R4nger
    Froyo May 12, 2020
    R4nger , via OnePlus 8 Pro , May 12, 2020 :
    I have tried using phone and car mode without success so I would say it's a bug. It was working on my Google Pixel.
    H1542153384332 likes this.
  5. H1542153384332
    Gingerbread May 12, 2020
  6. Hooryder
    Froyo May 13, 2020
    Hooryder , via OnePlus 8 Pro , May 13, 2020 :
    I have the opposite issue. My Android auto map is stuck on dark mode even in the day time.
    OnePlus 8 pro and Android Auto:
    Bluetooth connection seems more stable
    When you disconnect from the car the Android auto now continues to run on the phone even with the car turned off. You must now "tap to disconnect" in the slide down menu if the One UI.
    On the whole it seems to work better overall on with the OnePlus 8 pro but I have tried everything to fix being stuck in dark mode.
    R4nger likes this.
  7. vertro31
    Eclair May 13, 2020
  8. R4nger
    Froyo May 13, 2020
    R4nger , via OnePlus 8 Pro , May 13, 2020 :
    I have tried using all the options in the developer options and none of them enable daylight mode.
  9. vertro31
    Eclair May 13, 2020
    vertro31 , via OnePlus 8 Pro , May 13, 2020 :
    Android Auto has its own dev settings
  10. R4nger
    Froyo May 13, 2020
    Sorry I should have said, I tried changing all the Android auto developer options.
    There is also a bug where android auto doesn't cleanly exit when unplugged which stops the phone app from working.
  11. vertro31
    Eclair May 13, 2020
    do you see the same setting I see?
  12. R4nger
    Froyo May 13, 2020
  13. Hooryder
    Froyo May 14, 2020
    Hooryder , via OnePlus 8 Pro , May 14, 2020 :
    I changed all of those settings my Android auto is stuck on dark maps no matter what I change in the Android auto dev settings.
    ugh.
    but for all the bugs Android auto has had over the years every time I get a one plus phone it gets better and better especially the connectivity.
    it's flawless now.....well except for the dark map[e]1f602[/e]
    R4nger likes this.
  14. Clrnc
    Cupcake May 14, 2020
  15. H1542153384332
    Gingerbread May 16, 2020
    H1542153384332 , via OnePlus Community App , May 16, 2020 :
    I solved the Android auto night mode problem. I had 30 days of buyer's remorse and after finding out T-Mobile no longer sells the 7T on line I was able to find some local stores you still have them. I called T-Mobile and they sent a prepaid shipping label so I could return the OnePlus 8. Next day I was at T-Mobile store and bought the 7T for $499.00 Once home I transferred everything from 8 to 7T. The first thing I did after the transfer was check Android auto. Success it went to day mode, and later that night it was in night mode. My phone was in dark mode and never changed modes. The Android auto issue is in the 8 series.
    Hooryder likes this.
  16. Hooryder
    Froyo May 16, 2020
    Hooryder , via OnePlus 8 Pro , May 16, 2020 :
    yeah I know it's 8 pro issue or 8 series if you have TMobile version.
    FYI I don't by the TMobile versions because they throttle the tether data speeds. They don't do it with unlocked phones.
    But my wife still has her 7 pro so I tried it and it worked as usual.
    but honestly the 8 pro delivers the best Android auto experience I have had other than the dark screen connectivity is 100x better
  17. Hooryder
    Froyo May 16, 2020
    update just tested it and it works fine. Android Auto now responds to the settings in on the phone.
    Not sure but I gave it a day without using it and now it works as before.
    Actually better because I get no disconnects with this phone the 8 pro.
    It is no longer stuck in dark mode for the maps I am in the car posting this message all is fine!!!!
  18. tus123singh
    Cupcake Nov 6, 2020
    tus123singh , Nov 6, 2020 :
    I am too late to the discussion, but i found out that on my oneplus 7 pro the tone option in customization is actually controlling day and night mode on android auto. Dark tone leads to night mode to stay for ever, and light mode leads to day mode
