48
ROM Darkobas ROM (6.0.1) [AOSP + CAF]
  1. k2r79
    Cupcake Jul 16, 2016
    k2r79 , Jul 16, 2016 :
    You're awesome ! Thanks !
    jstepa likes this.
  2. Jacqen
    Ice Cream Sandwich Jul 16, 2016
    Jacqen , Jul 16, 2016 :
    Better to be sure :) thanks mates
    se7enlyn and jstepa like this.
  3. ziepicwaffle
    ziepicwaffle , Jul 16, 2016 :
    Warning!!!
    This ROM uses color os blobs for the camera so flashing incompatible kernels will break your camera! It will not work (not physically breaking your camera :p, just constant force closes and what not). Also color os blobs are meant for the oppo find 7 I believe which had a camera mounted differently than our device so the devs have to reorient it for the OnePlus one. That is why with some third party apps, the camera is upside down.
  4. jstepa
    KitKat Jul 16, 2016
    jstepa , Jul 16, 2016 :
    Erm, it was using color os, now it's snap cam again, and trying different kernels won't brake anything that can't be fixed with dirty flash ;)
  5. ziepicwaffle
    Ice Cream Sandwich Jul 17, 2016
    ziepicwaffle , Jul 17, 2016 :
    Isn't it still color os blobs? The snap cam is just the user interface, the blobs themselves are still color os? I don't think darkobas switched to cm camera blobs
    jstepa likes this.
  6. jstepa
    KitKat Jul 17, 2016
    jstepa , Jul 17, 2016 :
    Well who can tell anymore anything, one build it's this and another it's that ;):p
    ziepicwaffle likes this.
  7. Oschara
    Gingerbread Jul 18, 2016
    Oschara , Jul 18, 2016 :
    We all need a cough dirty flash from time to time. ;)
    jstepa likes this.
  8. springfixer
    Cupcake Jul 19, 2016
    springfixer , Jul 19, 2016 :
    Hi
    I am having problems with Bluetooth on this ROM that I am wondering if you could help with.
    Bluetooth connecting to car stereo doesn't work, it pairs and phone says its connected but stereo doesn't. Tryed exodus ROM and Bluetooth worked, but ROM isn't as good.
    Had same issue with cm13. But oxegen and exodus works fine.
  9. jstepa
    KitKat Jul 21, 2016
    KforHorizon likes this.
  10. saneaous
    Cupcake Jul 21, 2016
    saneaous , Jul 21, 2016 :
    Hi guys.
    I'm facing problems to install this ROM. After flashing it the phone get stuck in with that boot animation running over and over again!
    To mention I had CM 13 before!
    Any suggestions?
  11. KforHorizon
    KitKat Jul 22, 2016
    jstepa and ziepicwaffle like this.
  12. jstepa
    KitKat Jul 22, 2016
    jstepa , Jul 22, 2016 :
    Yes it sucks big time, this way is better if you use only this one ROM, but us flashaholics... ;):p
    No official statement, but last 3 builds has been only OTA
  13. rdhameja
    Jul 22, 2016
    rdhameja , Jul 22, 2016 :
    Check the following -
    - All partitions ext4?
    - Build 07-21 has bootloop problem as per G+
    - TWRP version?
  14. KforHorizon
    KitKat Jul 22, 2016
    KforHorizon , Jul 22, 2016 :
    Yeah i checked G+ after replying and flashed slim6. No nav bar yet and of course no dt2w! :p
  15. v1ks
    Gingerbread Jul 22, 2016
    v1ks , Jul 22, 2016 :
    Try this...
    download root browser from playstore
    open root browser
    go to etc folder
    open init.qcom.bt.sh
    when you get pop about script handler select view and RB text editor
    scroll half way down to where it says: setprop ro.bluetooth.hfp.ver 1.7 ---------Change this value to 1.5
    save the file and reboot the device and try
    i had similar issue where i cannot make any calls via BT when connected to my car stereo. and the above helped me...if it doesnt work then change the value back to 1.7.
    springfixer likes this.
  16. Deactivated User
    Jul 22, 2016
  17. ziepicwaffle
    Ice Cream Sandwich Jul 23, 2016
    ziepicwaffle , Jul 23, 2016 :
    It's Friday night for me here. Recently all of the Darkobas builds have caused overheating after several days, but I see that many people are fine. I'm going to wipe everything including internal storage and manually install everything to see if it works. :confused:
    se7enlyn likes this.
  18. se7enlyn
    se7enlyn , Jul 23, 2016 :
    tell me if there's any difference between manually installing all the apps and auto restore, with regards to the drain/overheating.
  19. ziepicwaffle
    I looked a little bit further (just a little bit, not too much :p) and when using google restore, it still restores a little bit of data and may cause more drains and stuff. I tried manually downloading all my apps from the play store and setting up everything including homescreens. I'll let you know. So far so good, still setting everything up.
  20. saneaous
    Cupcake Jul 23, 2016
    saneaous , Jul 23, 2016 :
    Only System is ext4, userdata is f2fs,
    TWRP is 3.0.2.0.
    It is mandatory to convert all partitions to ext4?
    Please give me hint how to do that.
    Thanks.
