48
ROM Darkobas ROM (6.0.1) [AOSP + CAF]
  1. ziepicwaffle
    Ice Cream Sandwich Aug 24, 2016
    ziepicwaffle , Aug 24, 2016 :
    Battery wasn't too good for me on 16th build. Which build of candy six are you on? Are you with the new kernel Dan made?
  2. se7enlyn
    se7enlyn , Aug 24, 2016 :
    july something.....:D
    ziepicwaffle likes this.
  3. sacrecaille
    Honeycomb Aug 25, 2016
  4. se7enlyn
    Ice Cream Sandwich Aug 25, 2016
    se7enlyn , Aug 25, 2016 :
    It's just isn't there, BAN! : )
    ziepicwaffle and jstepa like this.
  5. sacrecaille
    sacrecaille , Aug 25, 2016 :
    But it was before, no? why remove this function?
  6. ziepicwaffle
    ziepicwaffle , Aug 25, 2016 :
    I know it was there at one point, not sure about now. I just use Google camera version 2.7 or 2.5 I forget. Panoramas are good in that app. You can get the APK at apkmirror. Just Google "Google camera APK". The latest versions cause freezes, use the older versions.
    se7enlyn likes this.
  7. tosonny
    Cupcake Sep 22, 2016
    tosonny , Sep 22, 2016 :
    Hi folks!
    I am on COS 13.1.2 right now. I was searching for a Nougat-Rom and on this way I found hints concerning "best roms for oneplus one" (resurrection, sultan, darkobas, exodus). I have realy no idea which of those is the best and what the difference is. But what I have asked myself at first was: do the all have this nice feature to activate the screen with double-tap as COS 13.1.2 has it?
  8. ziepicwaffle
    Ice Cream Sandwich Sep 22, 2016
    ziepicwaffle , Sep 22, 2016 :
    every ROM I know of has double tap to wake at the moment. I'm on tugapowers nougat build and it even has that feature.
    jstepa and se7enlyn like this.
  9. l3viz
    Cupcake Sep 23, 2016
  10. se7enlyn
    Ice Cream Sandwich Sep 28, 2016
  11. Prinze Martin
    Prinze Martin , Sep 28, 2016 :
    Yea he's working for omni now :D
    Deactivated User likes this.
  12. Deactivated User
    Sep 28, 2016
  13. Cobrin
    Ice Cream Sandwich Oct 1, 2016
    Cobrin , Oct 1, 2016 :
    I'm still rollin with this one, it's still giving all it's got. Had sygic gps going for 5hrs (road trip) full screen brightness and still had 27% left by 2pm. I'm using apps left right and centre and it's not faulted, I really love that especially considering it's uptime is 198hrs24mins. I don't typically reboot it cause I'm slack to remember to do it and or I've had no need to.
  14. tye359
    tye359 , Oct 1, 2016 :
    Yeah this is a great ROM, but I've now moved to Android 7.0 :)
    ziepicwaffle and se7enlyn like this.
  15. Prinze Martin
    Prinze Martin , Oct 1, 2016 :
    Yea, they're a separate group of developers of OMNI ROm
    Deactivated User and se7enlyn like this.
  16. Tarfex
    Ice Cream Sandwich Oct 2, 2016
    Tarfex , Oct 2, 2016 :
    which ROMs are you using for Android N? the only one I've seen so far is TugaPower
  17. tye359
    tye359 , Oct 2, 2016 :
    Yeah that's what I'm running at the moment and seems to be working well, there are a couple of other ones - but I've not tried them
  18. striker280
    Gingerbread Oct 2, 2016
    striker280 , Oct 2, 2016 :
    What is your favourite build in terms of battery life? The final build doesn't seem too great
  19. ziepicwaffle
    ziepicwaffle , Oct 2, 2016 :
    If you're talking about Darkobas only, I think the consensus is that 7/22 is the best in terms of battery. However if I may, i recommend Tugapower's N builds. They are pretty battery friendly actually (.8 RC is at least for me) and very smooth. Since you're on Darkobas, I'm assuming customization is not too too important and right now the ROM is very bare bones so I don't think you'd mind.
    se7enlyn and striker280 like this.
  20. striker280
    Gingerbread Oct 3, 2016
