48
ROM Darkobas ROM (6.0.1) [AOSP + CAF]
  1. tye359
    Ice Cream Sandwich Jan 25, 2016
    tye359 , Jan 25, 2016 :
    it's been fixed now :)
    theapu and theshinybeast like this.
  2. Antoine Vdb
    KitKat Jan 25, 2016
  3. theapu
    Jelly Bean Jan 25, 2016
    theapu , Jan 25, 2016 :
    Marco man fastest dev in the planet.
    tye359 likes this.
  4. pluscat
    Gingerbread Jan 25, 2016
    pluscat , Jan 25, 2016 :
    Few questions about the ROM :
    - the apps My Android Tools and disable services don' t work in this ROM ????
    - can't find gprop file ????
    Maybe the users of the ROM know the answer to share , or can ask in G+ community.
    Could be related to SuperSU or SELinux status ????
    Nice development anyway.
    Thanks
  5. theapu
    Set selinux to permissive for disable services app.
    pluscat likes this.
  6. pluscat
    I'll try
    Thanks
  7. pablomoreno
    Lollipop Moderator Jan 25, 2016
  8. jstepa
    KitKat Jan 25, 2016
    jstepa , Jan 25, 2016 :
    All versions work, did you flash SuperSU v2.52?
    Without that, it will remain on animation screen, been there myself...
    theapu likes this.
  9. Antoine Vdb
    KitKat Jan 25, 2016
    Antoine Vdb , Jan 25, 2016 :
    Anyone using a more recent version of SuperSU than the 2.52 version ? I feel outdated with 2.52
  10. jstepa
    KitKat Jan 25, 2016
    As long as Marko says 2.52, I'm going to use that ;)
    What difference would newer make anyway?
    theshinybeast likes this.
  11. Antoine Vdb
    KitKat Jan 25, 2016
    Idk, maybe it's better. It's psychological, I hate to not be on the latest version of something
    csabreu, theshinybeast and jstepa like this.
  12. Deactivated User
    Jan 25, 2016
  13. theshinybeast
    Marshmallow Jan 25, 2016
    theshinybeast , Jan 25, 2016 :
    That's flashaholism for you, always wanting the latest of everything, root, TWRP, ROM, firmware, you've got it bad brother:p;):D
    KforHorizon, jstepa, yoshpe and 2 others like this.
  14. csabreu
    Ice Cream Sandwich Jan 26, 2016
    csabreu , Jan 26, 2016 :
    The information you provide is scarce. Have you carefully followed the OP instructions, i.e. flash first the latest firmware? Have you any of your partition formatted as f2fs? The kernel used by Darkobas ROMs don't support it. I guess you're doing a clean install (Wipe Data, System, Cache & Dalvik Cache), right.
  15. Deactivated User
    Jan 26, 2016
  16. lrodr74
    Donut Jan 26, 2016
  17. bhavinvis
    bhavinvis , Jan 26, 2016 :
    I am getting No SIM CARD DETECTED ERROR with 44S firmware..
    Same working for me on Sultan's ROM and RR...
    Rest everything works.
    On twrp 2.8.6.0
    Anyone else having same issue...
    @jstepa @Evokkimus any suggestion?
    jstepa likes this.
  18. jstepa
    KitKat Jan 26, 2016
    jstepa , Jan 26, 2016 :
    Yes, just tried 44S won't work with this ROM. Try the others in my thread, or I did found this "Frankenstein firmware" from xda (Currently using c1-11-0004 for a base and the c6-00241 modem/sbl1):
    https://www.androidfilehost.com/?fid=24385658843825783
  19. jstepa
    KitKat Jan 26, 2016
    You can use pretty much the Firmware you want which works for you, except Kitkat modem, as you can see above.
    bhavinvis likes this.
  20. rb2344
    Eclair Jan 26, 2016
