48
ROM Darkobas ROM (6.0.1) [AOSP + CAF]
  1. theshinybeast
    Marshmallow Feb 12, 2016
    theshinybeast , Feb 12, 2016 :
    You're right. I'll only talk shop from now on.
    My device is functioning very well on this ROM.
    The last update functions well.
    I like my OPO device.
    Basketbuild is up again.
    Thank you Marko.
    Are all of you enjoying the ROM as well? If so, good.
    Is that better @tye359? o_O :p
  2. 69gm
    Jelly Bean Feb 12, 2016
    69gm , Feb 12, 2016 :
    jstepa and theshinybeast like this.
  3. resporival
    Honeycomb Feb 13, 2016
  4. pranaviiit
    Cupcake Feb 13, 2016
    pranaviiit , Feb 13, 2016 :
    Please help me to flash this rom. I want to try this rom but every time I flash this rom, it is stuck on boot animation. What firmware to flash, which twrp version to use?
  5. ishtiyaaq50
    ishtiyaaq50 , Feb 13, 2016 :
    Use 2.8.6.0.Use the firmware provided on darkobas g+ page.Also you use bank gapps.
  6. se7enlyn
    Ice Cream Sandwich Feb 13, 2016
    se7enlyn , Feb 13, 2016 :
    use 2.8.6.0
  7. se7enlyn
    you need to flash supersu after you flash the gapps
    jstepa likes this.
  8. jstepa
    KitKat Feb 13, 2016
    jstepa , Feb 13, 2016 :
    Don't worry mate, people just don't understand us, world is not ready yet ;):p
    This new kernel is shit, all games twitching and swipes (when it gets faster) are not always recognized also I can't use KCAL color control. Tried also with Lightning kernel, no difference.
    Back to 0206-0 where there is still Sultan's kernel and everything works as it sould be...
    theshinybeast likes this.
  9. jstepa
    KitKat Feb 13, 2016
    TWRP 3.0.0.0 (unofficial and official) works fine as does 2.8.6.0
    Deactivated User likes this.
  10. pranaviiit
    Tried as instructed but same result. Usually how long does the initial boot take?
  11. se7enlyn
    1. boot takes about 10 minutes. first you will see the darkobas logo, then you should see the optimizing apps thingy.
    2. are you using supersu 2.57 ?
  12. pranaviiit
    I tried with supersu-2.65, now I'm trying with 2.52.
    Update: No luck this time also.
    Using twrp 2.8.6.0, flashed the firmware from google+ community group, latest build of rom, bank gapps and supersu 2.52. But still stuck on boot animation.
    I never faced this kind of problems with other roms.
  13. se7enlyn
    AFAIK, supersu2.52 and 2.67 works.
  14. se7enlyn
  15. SeanMartin
    Gingerbread Feb 13, 2016
    SeanMartin , Feb 13, 2016 :
    Here's a breakdown of how I flashed this ROM, hope it helps. (I was on Oxygen OS 2.1.4 previously, but have tried all sorts of CM12.1 ROMs)
    Using TWRP 2.8.6.0
    Download the Official OnePlus firmware. https://www.androidfilehost.com/?fid=23991606952604019 (taken from @jstepa helpful firmware thread)
    Download the latest Darkobas ROM file.
    https://s.basketbuild.com/devs/darkobas/bacon
    Download OpenGapps arm 6.0 nano package.
    http://opengapps.org
    Download the latest Beta SuperSU.
    http://download.chainfire.eu/897/SuperSU/BETA-SuperSU-v2.67-20160121175247.zip
    Reboot to recovery.
    Make a nandroid back up.
    Wipe, Advanced Wipe. Then Wipe Data, System, Cache & DalvikCache.
    Flash the Official OnePlus Firmware.
    Flash the ROM.
    Flash the OpenGapps package.
    Flash SuperSU 2.67
    Wipe Cache & Dalvik Cache (Just out of habit)
    Reboot. (Takes about 5 mins)
    Good luck and hope you get this awesome ROM up and running!
  16. se7enlyn
    this new kernel is pretty strange, in the battery chart , you can see doze is working but idle time is less than sultanxda's kernel. battery percentage keeps on dropping 1% every hour or so.
    jstepa likes this.
  17. csabreu
    csabreu , Feb 13, 2016 :
    By any chance have you formated some of your partitions with a filesystem other than ext4?
    If you do a clean flash (full wipe) and follow carefully the instructions in the OP it should work flawlessly.
    SeanMartin likes this.
  18. jstepa
    KitKat Feb 13, 2016
    I'll keep trying new builds, but if it stays the same, keep reverting back to 0206-0
    theshinybeast and se7enlyn like this.
  19. pranaviiit
    T
    Thanks. did a full wipe and flashed. Now It is booting.
    csabreu likes this.
  20. theshinybeast
    Marshmallow Feb 13, 2016
    theshinybeast , Feb 13, 2016 :
    Yeah they're sad souls who take life way too seriously
    I'm also not a fan of the new kernel but it seems as though Marko is intent on experimenting so we'll see where it leads. Meanwhile I'm going to try out this kernel as I've heard/read good things about it. I'll keep you informed.
    pluscat and jstepa like this.
