Darsh charge not working.
  1. thevinayjain
    Gingerbread Oct 21, 2018
    thevinayjain , Oct 21, 2018 :
    Whenever i connect the charger the phone charges only at the normal speed and does not dash charge. I searched the forum and found too many posts. OnePlus should really look into this issue as a lot of people are facing it. If anyone knows any solution to the problem please let me know. thanks!
  2. xnutzii
    Lollipop Oct 21, 2018
  3. Waveform Modifier
    Marshmallow Oct 21, 2018
    Waveform Modifier , Oct 21, 2018 :
    What are we facing? What problem? I don't have problems.
    xnutzii likes this.
  4. thevinayjain
  5. xnutzii
    xnutzii , Oct 21, 2018 :
    Then!↓
  6. thevinayjain
    good for you. many of them are facing the issue.
  7. Waveform Modifier
    You still haven't really explain what your problem is and what you have tried.
  8. Waveform Modifier
  9. thevinayjain
    I clearly told that dash charge is not working. only Red LED comes on when i charge the phone.
  10. thevinayjain
    That is what i am trying to say.
  11. Waveform Modifier
    What have you tried? You kept ignoring that important part
  12. thevinayjain
    I tried using another OnePlus cable and adaptor. If i keep plugging in and out again and again sometimes luckily dash charge comes on.
  13. Waveform Modifier
    Have your cleaned the port?
  14. thevinayjain
    yes and i don't think there's an issues with the Port. if there was an issue with the port then even normal charge wouldn't work.
  15. Waveform Modifier
    That's not true. However did you also tried another outlet?
  16. thevinayjain
    Yes i did
  17. Waveform Modifier
  18. thevinayjain
    yes i will. i just want OnePlus to take note and take measures on the issue as many people seem to be facing this problem. That is why i posted it in the forum.
  19. Waveform Modifier
    There is no OnePlus here
  20. arpitneogi1
    Donut Oct 21, 2018
    arpitneogi1 , Oct 21, 2018 :
    It's not getting the required voltage for fast charging so it's not working maybe . Try charging it somewhere where there is no voltage problems and inform
