Dash Car charger | Do I need it?
  1. DNvanBakel
    Froyo Feb 5, 2017
    DNvanBakel , Feb 5, 2017 :
    Searched the forum before I dared to ask this, but maybe I overlooked a previous topic.
    The Dash Car charger is out of stock, can I use the "old" charger of my OP2?
  2. Android450
    Marshmallow Feb 5, 2017
  3. Chirag AM
    Ice Cream Sandwich Feb 7, 2017
    Justbury likes this.
  4. DJSubterrain
    DJSubterrain , Feb 7, 2017 :
    You won't get dash charging without a dash charger and matching cable, it's as simple as that. If you use another charger the phone will charge but slowly, to be honest it probably won't run down too much if you're using it for GPS in the car but it's not going to charge very quickly.
  5. pa5t1s
    User of the Year 2014 Feb 7, 2017
    pa5t1s , Feb 7, 2017 :
    Any charger with 2100mAh/5V will work. Instead of a "dash" charge, you'll get a 'regular' charge (1H30 ~ 2H00)
  6. Narenderbalyan
    Cupcake Feb 7, 2017
  7. Mirimes
    Gingerbread Feb 7, 2017
    Mirimes , Feb 7, 2017 :
    Dude... I don't think dash charging items would be of any use with an op2. Search for a regular one cheaper and supported by your phone
  8. Raja Tomar
    Eclair Feb 7, 2017
  9. valiansz
    Cupcake Feb 7, 2017
    valiansz , Feb 7, 2017 :
    no need
  10. ZeroEight
    Eclair Feb 7, 2017
    ZeroEight , Feb 7, 2017 :
    if you already have good car charger, I think you do not need to spend money for this... but if you have no car charge you can buy... IMHO
    DNvanBakel likes this.
  11. DNvanBakel
    Froyo Feb 7, 2017
    DNvanBakel , Feb 7, 2017 :
    Ordered (and recieved today) 2 OP3T's.
    Want to use the car charger I used with my old OP2.
  12. Mirimes
    Gingerbread Feb 8, 2017
    Mirimes , Feb 8, 2017 :
    Sorry, misread ("car charger FOR op2" instead of "cc OF op2")
    So... it's like others said, will charge your op3t but slower than the dash. You just need a type-c cable.
  13. Scherpenseel
    KitKat Feb 8, 2017
    Scherpenseel , Feb 8, 2017 :
    For me personally: I don't really need the car dash charger. I'll make sure the phone is charged before taking it on travels and if I need any extra juice (for example when using it's navigation) plugging it in a normal charger is enough to keep it on 100%.
    I can only see a use for this if you by accident forgot to charge your phone and you only have a 30 minute drive ahead of you with no other charging possibilities.
  14. TheCustomer
    Cupcake Feb 8, 2017
    TheCustomer , Feb 8, 2017 :
    You can, but it obviously won't have the same speeds as dash charging.
  15. llano777
    Ice Cream Sandwich Feb 8, 2017
    llano777 , Feb 8, 2017 :
    It's your call. You have to think if you do short or long trips in car. I only have a dash charger at home. In my car I use the same that I was using with OP2. It's not that fast but it charges
  16. DNvanBakel
    Froyo Feb 8, 2017
    GOD234 and Ajay Gunjal like this.
  17. Manas.trivedi
    Cupcake Feb 8, 2017
  18. Ajay Gunjal
    Froyo Feb 9, 2017
  19. GOD234
    Gingerbread Feb 9, 2017
