Dash car Charger
  1. rajchhay
    Cupcake Aug 3, 2017
    rajchhay , Aug 3, 2017 :
    I am using oneplus 1 , 2, 3 & now 5. I observed that DASH CAR charger is not supporting Oneplus 5. If somebody have experience please guide me. oneplus 5 with Dash car charger, charges the same very slow!!!!!!
    Rajiv
  2. GlennGG
    Cupcake Aug 3, 2017
    GlennGG , Aug 3, 2017 :
    i tested it a lot if times .it look like it slows down whent the phone heats up . above 40 celcius i believe .. not sure . bit when i cooled down my phone in front of ac. it went dash again
  3. krv09
    Gingerbread Sep 8, 2017
  4. hoezaay
    Eclair Sep 8, 2017
    hoezaay , Sep 8, 2017 :
    hi I'm using a one plus 5 and a car dash charger and it works perfectly.
  5. meatandy
    Oreo Sep 8, 2017
    meatandy , Sep 8, 2017 :
    Check to make sure your USB cable is fully inserted into the charger.
  6. molsonalex
    Eclair Sep 8, 2017
  7. G_Manny_Ortiz_Zjim
    Eclair Sep 8, 2017
  8. G_Joe_Smart_Ltmx
    Honeycomb Sep 9, 2017
    G_Joe_Smart_Ltmx , Sep 9, 2017 :
    Works fine for me as well. I was disappointed that the Dash Car charger isn't a real car charger--it's an adaptor for the car lighter/charge port paired with a separate standard USB to USB-C lightning cable --but it does work fine.
    G_Sophie_F_WejC likes this.
  9. olh69
    Gingerbread Sep 9, 2017
  10. gubro
    KitKat Sep 9, 2017
