Dash Charge Cable via OnePlus 5
  1. Adrianeestrella12
    Cupcake May 6, 2020
    fazerboy0_3 likes this.
  2. fazerboy0_3
    Honeycomb May 6, 2020
  3. Matt 80
    Lollipop May 6, 2020
    Matt 80 , May 6, 2020 :
    No.
    Tobikage likes this.
  4. Madnezz4Ever , via OnePlus Community App , May 6, 2020 :
    Read the reviews or ask the seller if it works as you would get mixed answers asking here.
    In my opinion it might work with dash charging as it supports fast charging even though some say only OnePlus cables are supported. I use a non OnePlus cable that works fine with dash charging.
    It's worth it to try if it's cheap enough and you have no other options, but don't expect it to be as fast as a OnePlus cable.
    You can also use a warp charge cable from OnePlus with your phone.
  5. sumitranjan.panda
    Gingerbread May 7, 2020
  6. wileyc
    Jelly Bean May 7, 2020
  7. mohitchhabra20
    Cupcake Jun 22, 2020
    mohitchhabra20 , via OnePlus 6 , Jun 22, 2020 :
    Hi,
    Can you let me know which cable do you use for dash charging. Thanks.
  8. nagaphanisharma
    Cupcake Jul 1, 2020
  9. Matt 80
    Lollipop Jul 1, 2020
  10. Waveform Modifier
    Marshmallow Jul 1, 2020
