dash charge compatible cables?
  1. Shanxybeast
    Eclair Oct 5, 2017
    Shanxybeast , Oct 5, 2017 :
    I'm looking for a recommendation on dash charge compatible cables that are anywhere from 6ft to 10ft in length. preferably braided.
  2. G_Joe_Smart_Ltmx
    Honeycomb Oct 5, 2017
    G_Joe_Smart_Ltmx , Oct 5, 2017 :
    You can use non dash charge cables on the OP5. Dash charge is only used by OnePlus (Oppo phones use the same technology under a different name) so my guess is you can only get them from OnePlus or Oppo or someplace that sells their official accessories. Amazon sells the OEM Cases that are available in the OnePlus Store so they might also carry the compatible cables.
  3. Shanxybeast
    Eclair Oct 18, 2017
    zukky46 and 97pratyush like this.
  4. Epiphone097
    Gingerbread Oct 18, 2017
  5. DrAakash
    Jelly Bean Oct 18, 2017
    DrAakash , Oct 18, 2017 :
    There are no such cables on the market.. none with that kind of length anyway.
    What you can do l, however, is to buy a normal extension cable for your wall plugs. Use your dash charger with the included cable anywhere then.
  6. Shanxybeast
    Eclair Oct 18, 2017
    Shanxybeast , Oct 18, 2017 :
    while I appreciate the out of the box thinking, that really doesn't work for me at work
  7. DrAakash
    Hmm.. there are really no options then. How about a power bank?
  8. Shanxybeast
    Eclair Oct 18, 2017
    that's just another thing to lug around and hope customers or co-workers don't jack it and yet another thing to charge
  9. DrAakash
    Then your only option is to get a longer, albeit normal usb type-c cable and be content with the slower charging speeds.
  10. Jazman23
    Cupcake Oct 18, 2017
    Jazman23 , Oct 18, 2017 :
    I've seen loads of cables advertised as working with Dash charge but they don't. The actual connections in the USB part of the cable are different to a normal one which is why it doesn't work unless you use a genuine cable.
    I haven't been able to find any cables other than the genuine one, you can pick up a genuine one on amazon fairly cheap. Doesn't solve your problem though.
    I have a 6m cable that claimed to be dash charge but it isn't, it does however allow my 3T to charge up from 10% to 100% in about 1.5 hours if that's helpful at all?
    Shanxybeast likes this.
  11. Shanxybeast
    Eclair Oct 18, 2017
    or switch phones. let's face it's, dash charge is not really a feature anymore when it compares to the versatility and cheaper less proprietary Qualcomm Quick Charge solutions.
  12. Shanxybeast
    Eclair Oct 18, 2017
    this was very helpful and helps re-affirm what I was afraid of.
    Jazman23 likes this.
  13. Jazman23
