2
Dash charge has stopped working
  1. F_Ashutosh_Mal_tHsO Cupcake Jul 9, 2018
  2. Robson_DeluXeXBR Eclair Jul 10, 2018
    Robson_DeluXeXBR, Jul 10, 2018 :
    hello, can you show me what parts I need to replace? thanks
  3. aswinpv Cupcake Jul 24, 2018
    aswinpv, Jul 24, 2018 :
    Tried your method. It started charging but randomly stopped charging 10 min later.
  4. Ferefe Eclair Jul 24, 2018
    Ferefe, Jul 24, 2018 :
    try cleaning Inside the charging jack and the cable connector. It happened to mine and this worked
  5. Abhi Dahiya Ice Cream Sandwich Jul 24, 2018
    Abhi Dahiya, Jul 24, 2018 :
    Overtime cables lose their ability to function properly. Try charging your phone with another Dash Charger. If it works fine it means cable isn't working anymore as it should.
    Just buy a new Dash cable from OnePlus.
    Also try to clean ports on both charger as well as phone.
  6. aswinpv Cupcake Jul 25, 2018
    aswinpv, Jul 25, 2018 :
    Ok. But is it possible there is something wrong with the software? Because this started happening right after I used a normal charger of another company. If so what can I do to to fix my phone?
  7. aswinpv Cupcake Aug 1, 2018
    aswinpv, Aug 1, 2018 :
    You're right. The problem is with cable. Ordered a new one.
    Abhi Dahiya likes this.
  8. AbdNz Froyo Aug 1, 2018
    AbdNz, Aug 1, 2018 :
    I was also facing the same but after cleaning the ports of phone as well as cable with petrol, the problem was gone. You can also try that
  9. Abhi Dahiya Ice Cream Sandwich Aug 1, 2018
    Abhi Dahiya, Aug 1, 2018 :
    Told you. At least OnePlus cable lasts 1+ year. My Samsung's original charging cable used to be dead within 6-7 months.
  10. guy.tremblay Cupcake Feb 10, 2019
    guy.tremblay, Feb 10, 2019 :
    Hello there,
    Similar sequence of events with a oneplus car charger. Dash charge not working anywhere now for my OnePlus 5. How did you get this resolved?
    Thank you
  11. guy.tremblay Cupcake Feb 11, 2019
    guy.tremblay, Feb 11, 2019 :
    Finally rough cleaning with rubbing alcohol restored Dash charging. Was just a dirty slot.
  12. guy.tremblay Cupcake Feb 11, 2019
    That worked for me too.
  13. Q1549682606645 Cupcake Feb 11, 2019
  14. vipul019 Cupcake Feb 11, 2019
    vipul019, Feb 11, 2019 :
    Clean the charging port. Overtime dust settles in it which makes the connection weak. Use a toothpick to get the dirt out (donot use any metal).
